Another Camaro?! I think so!
Old Nov 27, 2002 | 06:16 AM
SuPeR SpOrT's Avatar
I was looking in teh papaer today and I see an 1985 Camaro Z28
305 T-tops air ac PW PL Magnaflow exhaust, Emissions $3000/obo
Sounds goo to me! I might go check it out..
what do you guys think, are there any specific locations that I should look at on the car..
Old Nov 27, 2002 | 07:19 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I would say for canada, rust, esp the floor boards.
Also check for bondo in the non-obvious spots, like the top of the fender, top of the doors, etc. How to check, take a average size magnit with ya. If owner dont mind, try sticking it to the car in a few spots. Don't drag it on the car, but if you feel it try and pull, its good sign of no bondo.
Old Nov 27, 2002 | 11:12 AM
alrighty..
Old Nov 27, 2002 | 02:57 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Re: Another Camaro?! I think so!
Okay rust isn't the big deal, its where the rust is. Make sure the rear spring shackles are not rusted though, or too rusty. Check the spring joint on the rear axle for rust through.
Check the strut towers for holes. Next wheel wells. The front are usually good, but the rear takes it all. If you see rubber rockguard in the rear wheel wells, ask if you can remove the rear inside panels, and chack for rust around them. Lots of people cover this stuff up.
Check floor, mostly driver side will be weak. Often the rust from the inside out, So it could be almost rusted through from the inside and not be able to see it.
Now make sure you can take it for a drive. Cause if you can only yard drive it the clutch could be gone (or missing OD for auto) and you won't know till the cash is in their hands and you on your way home.
Final advice, 3000 it better be in really great condition, or have a TPI. Try to beat him down, like 2300-2500.
Old Nov 27, 2002 | 04:24 PM
KED85's Avatar
Fly down to Los Angeles for some RUST FREE TURKEY & TRIMMINGS.
Really these things rust out that bad?
To me, you're making it sound like an old Plymouth after one snow season!
Old Nov 27, 2002 | 04:29 PM
oh *** yeah, my old car every time you shut the hood, about a liter rust fell off
Old Nov 27, 2002 | 04:40 PM
KED85's Avatar
When I visited Canada back in 1973 or so, I recall seeing an older Ford (like a 68-69 model), door skin was flapping in the wind as the rust had eaten away so much door.
I WAS STUNNED!!!!!
Only when I lived on the Pacific beach in Marina del Rey (early 80's) do I recall seeing cars that bad.
All the wrecks in the yard no rust at all. Ok Barely any rust....
Old Nov 27, 2002 | 09:57 PM
your lucky if you see an early 80's Camaro here, all of them have been suduced to rubble.
Old Nov 28, 2002 | 08:41 AM
KED85's Avatar
How much do people charge to ship a car from Los Angeles to Canada?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
