cam help
Old Jan 16, 2003 | 11:01 AM
junkie's Avatar
Car: 84 camaro berlinetta
cam help
hi all i dont have a clue about cams so i asked a guy at comp cams told him i was all stock and wanted a performance cam does this sound any good?
PART NUMBER 16-232-4
ENGINE CHEV. 60 DEGREE V-6
GRIND # CV6E 252H-10
DESCRIPTION HIGH ENERGY
INT EXH
VALVE ADJUSTMENT HYD HYD0
GROSS VALVE LIFT .425 .425
DURATION AT
.006 TAPPET LIFT 252 252
VALVE TIMING OPEN CLOSE
AT .006 INT 20 52
EXH 60 12
THESE SPECS ARE FOR CAM INSTALLED
AT 106 INT C/L
INT EXH
DUR AT .050 206 206
LOBE LIFT .2835 .2835
LOBE SEPARATION 110.0 INT MASTER ID 252H-4
ADVANCE 4 EXH MASTER ID 252H-4
RECOMMENDED CC VALVE SPRINGS 980-12
Old Jan 16, 2003 | 04:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, why not, sounds good. If the recommendation came from the cam manufacturer, and that's the one they recommended out of all their 2.8 cams, they probably have a good idea about what they're talking about. There's probably better and worse cams out there, and I'm sure you'll get a ton of "buy this and don't buy that" answers.
What you should do is email all the 2.8/3.1 V6 cam makers and ask them what cam they recommend. Put all the cam specs in a big chart, and then you'll be able to see differences. Or if you want to play dirty, take those cam specs, mail them to crane, and say "comp cams recommended this cam to me. I was wondering what you could recommend for me in a Crane cam?" Pit the companies against one another.
Do you have emissions testing where you live?
Old Jan 16, 2003 | 04:27 PM
junkie's Avatar
ya i have emission tests but i only have to get tested 1 more time then my car will be 20 years old ..so no more e test ..plus there are ways of getting them anyways
thanx
Old Jan 16, 2003 | 08:18 PM
86camarodriver's Avatar
If it was me I would save the money and go with an MPI set up. When my car was stock minus free mods and aluminum wheels I beat up on these two carbed 2.8's with 5 speeds all the time, it was not even a race LOL. The cams also work better with MPI from what I have heard. If you have the stock steel wheels you can do what I did and replace them with aluminum Z-28 wheels for 100 bucks, no spacers needed. Go to cranecams.com, If you look around you will fine the cams for the 2.8, 3.1, 3.4, they have emissions cams and non, I am going with a nice non emissions cam. Again with the dinky carb and intake it will not work as good as it could.
Good luck
David
Old Jan 17, 2003 | 08:23 AM
82-T/A [Work]'s Avatar
Another Option
Also thought I would mention that there is another shop, "Anderson Racing Incorporated" that builds stroker kits for our motors, etc...
but one of the services they offer are better camshafts.
They offer this one camshaft that is equivelant to the Crane CompuCAMS 2030 Camshaft. This cam is their PHASE 2 cam.
It's STILL 100% compatible with the stock computer, but has a slightly higher lift and duration than the Crane Cam does.
It's also like $60 dollars cheaper too.
http://www.engine-parts.com/GMV6/28camspecs.html
Check it out.
I purchased their 2.8 to 3.1 stroker kit (with .030 overbore pistons) and their Phase 2 cam. I'm having them installed right now as we speak.. complete rebuild. I'm totally psyched. I expect I'll be running mid 14s with this conversion.. of course, this is in a 2,500 pound Fiero though.
Old Jan 17, 2003 | 08:34 AM
junkie's Avatar
thanx 82 ta ..sounds good i might go for phase 2 like your saying..let me know how it turns out for you
Old Jan 17, 2003 | 08:36 AM
Yeah, I won't actualy get the engine back until the first week of February, but I should have it back in the car and ready to go within a week. I'll have to drive like a grandma for the first 1000 or so miles I think they say... but after that, I'll give it all it's got!
Old Jan 17, 2003 | 08:50 AM
KED85's Avatar
How much is your engine & machining bill?
Last guy said his cost $3000 and he had only a 2.8 still.
New GM OTC 3.4 mills go for only $1700 & a 12,000 warranty, too.
Old Jan 17, 2003 | 09:01 AM
The total cost for EVERYTHING, which includes buying the 3.1 stroker kit, and the fancy cam-shaft... everything is costing a total about about $1,600 bucks.
And I end up with a high-output 3.2
(.030 3.1 pistons)
Todd
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
