2.8 running 11.s YOU GOTA SEE THIS!
Old Feb 21, 2003 | 11:05 PM
firebird13's Avatar
Camaro rs 88: huh?
Throop13: sup...
Throop13: I see you got an 88camaro
Camaro rs 88: whos this?
Throop13: I got an 87 firebird!
Throop13: i seen you was in car chat
Camaro rs 88: ok
Camaro rs 88: im in troubleshooting
Throop13: So..you got one?
Camaro rs 88: yep
Throop13: what size engine?
Camaro rs 88: 2.8 interceptor package
Throop13: you got an 2.8?
Camaro rs 88: yep
Throop13: ...you like it?
Camaro rs 88: excellent
Throop13: Why?
Camaro rs 88: is mpfi with icep package runs 11.4 in 1/4
Throop13: Dont fill bad i got an 2.8Fi my self!
Throop13: mp?
Camaro rs 88: mpfi
Throop13: Wtf that mean?
Throop13: oh
Throop13: Multi port fuel injection?
Camaro rs 88: yours is throttle body injected?
Throop13: Fuel
Throop13: injection
Camaro rs 88: what style?
Throop13: Liek the rest
Throop13: ? let me show you a pic
Throop13: of what mine looks like but not it!
Camaro rs 88: several styles mpfi and tbi is fuel injection
Throop13: http://www.cardomain.com/member_page...1_134_full.jpg
Throop13: thats what it looks like
Throop13: Whats an ice pack?
Camaro rs 88: mpfi is 1 injector per cylinder and tbi is 2 injectors total with a carb style set up
Throop13: I have mpfi
Camaro rs 88: intercep package is police issue for performance
Throop13: whtas it do?
Camaro rs 88: brb
Throop13: how could you supe it up?
Throop13: it up to be that bad?
Camaro rs 88: saw yours and is same engine, but mine was diff from factory to start with cam, rings and total performance with tranny high end and all that stuff,, rear end
Throop13: I dont see how it could hit 11s though
Throop13: thats not mine exactly just what it looks like
Camaro rs 88: boost your with a hyper chip in ecm from autozone at 140$
Throop13: With out running niturs
Camaro rs 88: no nos here
Throop13: what els?
Camaro rs 88: but they did a number onit factory
Camaro rs 88: runs 140 in 4th at 3000 rpm
Throop13: I dont see how that thing can do it though
Throop13: Every dyno?
Throop13: Automatic or manual?
Camaro rs 88: 5th is so high that i get worried about lift off befor i can shift to get the rpms up.... not dynoed
Camaro rs 88: 5 spd
Throop13: oh i c
Throop13: Man 11.s in a 2.8 thats crayz
Throop13: The only way i thought you could do that is with nitrous and like twin turbos..
Camaro rs 88: i got lucky as hell.... but parts are expensive to match up
Throop13: how much hp does the chip give you?
Camaro rs 88: no turbos or anything like that for this car
Throop13: Thats wild
Throop13: How much money you put into it?
Throop13: Do you tihnk its possible to get mine to do that?
Camaro rs 88: the hyper chip will give you about 20 to 65 hp depending on how you set it up... comes with a handheld to adjust... i dont have because it would lower what ive got
Throop13: How much hp do you thik you putting off?
Camaro rs 88: was better than most performance parts off the street when i got this one
Camaro rs 88: no clue as hp on mine... will smoke em in 2nd though at 40mph
Throop13: man..that thing is fast..just dont see how you can run 11.s..but I guess it can be done..you got headers?
Camaro rs 88: it had them but they rusted out and i replaced with standard manifolds on dual exh. setup ... no cats either
Throop13: oh ic
Throop13: Sounds awesoem got any pics of your car?
Camaro rs 88: not online... no cam to transfer pics
Camaro rs 88: had lights ontop and i removed them....
Throop13: oh yea?
Throop13: lol
Camaro rs 88: gloss black with racer stripe from front tire narrowed to wider in back at rear tires
Camaro rs 88: stripes is yellow outlind in gold
Throop13: why would they have a 2.8 for a cop car why ont a 5.7?
Camaro rs 88: chevy said standard should be 205/70/15 but most cars ive seen is 14's
Throop13: oh..you sound liek you know what your talkign about
Camaro rs 88: the only prob ive got is the driver side roof is rusting out near window and will cost more than the body replacement to fix it
Throop13: oh
Throop13: Mines silver and dont have no rust
Throop13: great shape
Throop13: paid 1500 for it....but motor has 130,000 milse on it
Throop13: Interior really great besides crack in dash
Camaro rs 88: my motor has 85k and dash was cracked also where the junk was screwed in and i put my eq under the vents in the middle of dash and cracked top worse
Throop13: oh lol
Camaro rs 88: i replaced the oil pan twice allready from scraping bottom on back roads
Throop13: lol..
Camaro rs 88: also bought 1 ton military 4x4 chevy truck single rear tires with diesel and put 350 40 over with edelbrock intake performer...need to get better carb...mine is junk
Throop13: lol expensive
Camaro rs 88: pulls anything though but top end is about 60 wound out
Camaro rs 88: great in the rivers and sand
Throop13: lol yea
Camaro rs 88: engine chromed out about built for 5 grand
Camaro rs 88: truck was 850 cash
Throop13: sounds good
Camaro rs 88: put about 2000 in tires
Camaro rs 88: run them trees down with the guard i built and no problems
Throop13: Twin-turbo V6 510
Throop13: here its not in a camaro or firebird though
Throop13: but same engien
Camaro rs 88: brb
Camaro rs 88: any specs on it?
Throop13: yea hold on
Camaro rs 88: brb
Throop13: What do you think about that?
Camaro rs 88: should paid that much for jet engine instead... but impressive
Throop13: lol yep bet its fast
Camaro rs 88: didnt see speeds or records
Throop13: yep i know
Throop13: suxs
Throop13: join
Throop13: you going to join?
Old Feb 21, 2003 | 11:08 PM
firebird13's Avatar
Heres the car wit twin turbo 2.8 its been on here before but heere fo the poeople that haent seen it!
http://www.bryanf.com/mycars/510V6.htm
Old Feb 21, 2003 | 11:13 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Sounds like dude has no clue what hes talking about.
20 to 65hp from a chip
I want one of them chips. I would have no problem paying 140bux to add 65hp to a stock car. LOL
Old Feb 21, 2003 | 11:35 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
hahaha what a retard, lamo
Old Feb 22, 2003 | 12:38 AM
firebird13's Avatar
Thats what i was saying..oh well..let him be stupid lol
Old Feb 22, 2003 | 03:18 AM
rezinn's Avatar
Could you post his phone number and email address so we could make fun of him some more?
Old Feb 22, 2003 | 09:22 AM
84TAProject's Avatar
Ill bet this will be locked, but anyways. Sounds like the kid here who tells me its a shame I can't put a chip in my T/A (I could but not worth it IMHO) since they make huge differences. Or the person yesterday who told me his neghbors cop crown vic had a twin turbo big block V-8. My other favorites are the factory 6 speed 390 hp 76 vette, and the 230 hp stock LO3. I hope to race the LO3 this spring, and then laugh my *** off as he tells everyone I must have like 450 hp to do that to him.
Old Feb 22, 2003 | 10:06 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yanno.. that's not quite funny anymore.. I had someone with an lo3 tell me they did have 450 hp.. said the previous owner dropped a race motor in it... was a long time ago.. but I notice his LO3 wasn't any faster than mine, and I'd be happy if mine was able to push stock numbers..
EDIT--- and.. after actually steeling my stomach so I could read the top post.. *LOL* That's worse than the 3.1 running around here with viper-style stripes and Onseki R stickers on it (misspelled, but I could care less. It has import performance stickerpower on it)
Old Feb 22, 2003 | 04:55 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
It is entirely possible to get around 20-40 HP from a chip. But the thing is your are goning to be spending ALOT of time tuning it properly.
Old Feb 22, 2003 | 05:44 PM
Dale's Avatar
Engine: 350 S-TPI
Ok v6, I may agree with you, however, not a hypertech he bought off the shelf for 140 buxs.
Esp when hypertech does not list one for the v6, and jetchip only list ganes of 10-15hp.
Old Feb 22, 2003 | 09:12 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Oh my ***..I can't believe I just read that. I feel...dumber for having read that.... ***....smoking his tires at 40 mph in 2nd...mmmhmm....sure...11's on an N/A, non-nitroused 2.8? Suuuure. You have to be lucky as hell to get a V8 to run 11's on all motor....a 2.8? HA! No way in hell.... Notice the lack of technical data to back himself up too? If the thing run's 11's, surely he'd brag about his parts combo in more technical detail than "saw yours and is same engine, but mine was diff from factory to start with cam, rings and total performance with tranny high end and all that stuff,, rear end "
Oh yes, I'm sure a tranny rebuild, a beefy rear end, a cam, and piston rings will net you 11's for sure in a 2.8 that came with 135 horsepower. Yep. And my Mustang ran 4.85 at 220 mph last week.. It'll pull mid 4's on a good day but I had a hard time hooking it into 3rd.
Was this an AIM conversation? Must...refrain.....
Old Feb 22, 2003 | 11:27 PM
I just talked to the person, I couldnt resist, I was bored. I deleted the first part about it being an old cop car and faster than a 350 though and the part where they said "what's 11's."
Though this is non tech, this goes to show you how misinformation causes people to think things about all fbodies and if you dont know what your talking about then just shut up.
Camaro rs 88: he rebuilt the engine last year since we had it apart to fix the oil leak
YouCanRotInHell: my 2.8 used to leak oil, i fixed it though
Camaro rs 88: i scraped bottom on a dirt road and ripped the pan a big hole
Camaro rs 88: he was pissed to come drag it home.. then he broke the plastic front end too
YouCanRotInHell: i let a buddy of mine drive the car and he hit a rock with the oil pan, just dented it
Camaro rs 88: with the chain
YouCanRotInHell: that sucks
Camaro rs 88: he cant find the parts to fix it like he wants it so it is just setting up now
Camaro rs 88: asl
YouCanRotInHell: 18/m/ny
Camaro rs 88: 24 f tx
Camaro rs 88: you have one
YouCanRotInHell: ive got an 84 camaro and an 84 trans am
Camaro rs 88: we had 84 till we burned it
YouCanRotInHell: you burned it?
Camaro rs 88: he had hydro in it and the cables caught on fire
Camaro rs 88: nitro not hydro
YouCanRotInHell: that sucks that stuff can be dangerous
Camaro rs 88: ins paid us off about 12 g
YouCanRotInHell: awesome, you could build a hell of a car for that kind of dough
Camaro rs 88: not really
Camaro rs 88: he put about 8 into a 85 chevy 4x4
YouCanRotInHell: i could build a nasty turbo smallblock for my car with that cash
YouCanRotInHell: whats that got for mods
Camaro rs 88: he spends all our money on f***in cars
Camaro rs 88: whats a turbo smallblock?
YouCanRotInHell: small block chevy, turbocharged, can make a ton of power
Camaro rs 88: he took out a diesel engin and built a 350 and had some shop do something to it before he bought new plunger things for it
YouCanRotInHell: awesome, our old truck has a 305 in it
Camaro rs 88: he orders stuff from badger and edelbrock alot and got the engine all krome
YouCanRotInHell: cool, oh well its late in ny im off to sleep
Old Feb 23, 2003 | 12:02 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
It appears this young lady has no idea what she is talking about.
But I can almost understand her Chip idea. I read on MSN a few months ago an article about how the camaro and Firebird died was because of the latest "50hp" chips that were everywheres.
The article said very bluntly that you can just go buy a chip for strap it on your stock Focus, or Civic and gain 50hp. Its sad because an article like this would be read by millions, and misleading to thousands who knew nothing.
Obviously she is trying to lead people on. Infact she might just be saying this crap sitting in her chair laughing at people who shes thinks is believing her every lie.
Some people just don't know how stupid it is to lie about something so trivial.
Old Feb 23, 2003 | 02:44 AM
rezinn's Avatar
Stop wasting your time guys. There are women out there who can spell chrome and know that "a" and "lot" are separate words.
You got it, Joe. It's like a virus.
Old Feb 23, 2003 | 10:30 AM
Sorry guys I was really bored last night
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
perZ
Aug 21, 2015 05:51 PM
86Base
Aug 8, 2015 01:34 PM
