Gas Milage
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Bad O2 Sensor to begin. Check for codes too, could tell you a lot if there are any. Something that was giving me really bad mileage for a while was a cracked exhuast valve. i was wasting an entire cylinder's worth of gas evey time the engine came around. Bad air filter ruins milage too. Misadjusted TPS and or bad ignition components can do it too. I'm sure others will follow with more info, but that's all i can come up with right now...kinda sleepy.
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Give us a FULL list of what has been done. Otherwise there will be 50 posts of people saying "did you change this?" and another 50 posts saying "Yes, we changed that"
Car: 1983, 1986
Originally posted by ajm_shorty
02 sensor , Oil Pan...thats about it
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Hey can I attach a trumpet file to my tuneup list?
AJM, most mileage and power problems are related to basic tuneup parts. Guys come in here (and on the tech board) all the time, wondering why their car is so slow, because they've put on an exhaust and a K&N air filter. Of course, they forgot about doing everything else.
Here's the last posting of the tuneup: https://www.thirdgen.org/techbb2/sho...hreadid=162251
hey this is his friend with the camaro with bad millage i have changed the oil, plugs, plug wires, o2 sensor and every time i run it for codes it comes up with bad 02 and engine running lean and i cant figure out why i cant fix it.
Car: check
Engine: check
Transmission: check
RBob.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Originally posted by MDv6man
well then it sounds like a job for [trumpet sound] TOM P'S MAJOR TUNEUP!!![/trumpet sound] do a search for it. It will most definitely help.
I'd check the 02 wiring and possibly have your injectors cleaned. Easiest way to do that is buy a spare set from a junkyard and send them to Rick or Rich (can't remember) at cruzinperformance
Car: check
Engine: check
Transmission: check
i wanted to test the injectors but i dont know what the resistance should be because i can not find it in any books i look in plz tell if if ya know
RBob.
hey i found an exuast like right where the manifold bolts and i thinkg that might be it cause the o2 wont be reading and gas in the exuast and just dumping more and more in there but its just a theory i dont know if thats it but i dont know how to fix it other than buying an new exuast.
tonys91rs
Oct 10, 2015 03:31 PM
its been pissing me off bad
