car stalling plz help
Old Mar 21, 2003 | 12:17 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
sup guys i have a 89 rs with a 2.8 and an auto trans , well if you drive the car for about a half hour it stalls on the highway and in the city no matter what speed you are going . if i pull over and wait 10min the car starts up and runs fine for another 10min then stalls again , i checked the timing and its at 10 degrees , also checked the fuel pressure and its around 35lbs . im not sure what it could be plz help i realy need this car to run and dont have the money to leave it sit in a shop for a week. thanks..
Old Mar 21, 2003 | 12:45 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Vaccum leaks....make sure all plugs/wires are good...EGR at times has been known to be suspect...no codes from the computer or anything?
Old Mar 21, 2003 | 12:51 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
no codes , the egr makes a chattering noise so i took it off cleaned it and made sure it wasent leaking and seemed fine , i just did a complete tune up about 4 months ago with a new coil , im lost here
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
The next time it stalls, check for spark. Could be an ignition module or cioil dying after the car gets warmed up.
Old Mar 21, 2003 | 01:52 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
well i drove the car till it stalled again and it does it after the car warms up so after it stalled i checked for spark and there was none , the coil is frairly new so do you think it would be the icm? or is there anything elese that would cause this problem ?
Old Mar 21, 2003 | 02:00 PM
MDv6man's Avatar
Car: 1983, 1986
Aside from the coil, ICM, or pickup coil...no. There are exceptions but that usually means bad wiring. I would suspect a bad ICM.
Old Mar 21, 2003 | 03:10 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
what can i say MDv6man your the man thats what it was now the car runs great thanks a **** load . :hail:
Old Mar 21, 2003 | 03:53 PM
Azure's Avatar
Hey, I tried too! lol
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
