Random thought about MAF removal...
Old May 19, 2003 | 08:03 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
So, a random though pops into my head today...
My 1986 2.8 Firebird has a MAF sensor, but no MAP sensor.
My 1994 3100 Grand Prix has a MAP sensor, but no MAF sensor.
My 1997 3800 Grand Prix has BOTH a MAP sensor and MAF sensor.
Since the 2.8 and the 3.1 are similar engines, could a conversion be done to remove the 3-wire MAF sensor unit, and replace it with a MAP sensor, and do any electrical conversions to get it to work properly with the ECM? Obviously there would need to be a customization of the intake manifold to accomodate the sensor, but that's the easy part...
What are your thoughts?
Old May 19, 2003 | 10:19 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You have to swap ecu's to a SD computer.
You can repin the MAF connector to run to a map.
Intake mod? Just run a vacuum line to the MAP sensor, you're done
Old May 20, 2003 | 03:46 PM
What is "SD", and is the conversion worth it? Can I recycle my upgraded ECM chip, or do I need to pick up a new one?
Old May 20, 2003 | 04:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
SD = Speed Density = the name given to the way air flow is determined when using a MAP sensor.
This was actually done on gen II FWD 2.8's with the 5-pin "combination" MAF + MAT sensor. I think there was also a service bulletin out for the 2.8 f-bodies, too. Anyway, the MAF's commonly broke, as we know. GM released a "fix" that involved a new computer chip and a MAP sensor. The MAF relay was disconnected, but the wires going to the MAF were still plugged in to allow the MAT to still function. (5 wire MAF = 3 wires for MAF, 2 for MAT).
The MAP got tagged in at the connector for the MAF relay, and wired to power and ground, and had a vac line run to it.
Now that was for the Gen II 2.8's (front wheel drive). Might have to do some research to determine if the same applied to a Gen I 2.8 in an f-body.
Old May 20, 2003 | 04:59 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
if your not making any serious, and i mean serious power, its not worth it
you have to re-pin to a new ECM connector that will fit a 730 ECM
its usually done to eliminate the MAF sensor (because its a restriction) on hi power engines
the only reason i could see to warrant this being done in this situation, is to eliminate the MAF sensor because it can be troublesome
the 730 also has a faster baud rate than the MAF ECM
Old May 20, 2003 | 10:29 PM
I hope not! It's still only a 2.8...
Atually, I wanted to get it out of my way on the intake. The inlet side is not parallel with the outlet side, so it makes my custom intake look a little silly...
Well, never mind then. It was just a thought. Thanks for the info!
Old May 21, 2003 | 02:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Teal, do you know if the FWD Gen II's used the same ECM as our Gen I 2.8's? That car of my dad's had a sticker on the driver's side shock tower. It mentioned a speed density conversion, said the chip was replaced, and gave a service bulletin # to "read before servicing this car"- it didn't mention that the computer was replaced. I wish I had thought to write that damned # down; the car's a few years gone already.
If the ECM's were the same on Gen II FWD a-bodies and Gen I RWD f-bodies, then the ECM wouldn't have to be changed for an SD conversion. In fact... that Gen II 2.8 must've had a CSI, right? The sticker didn't mention anything about the CSI removed.
This might be good info for the "I want a turbo" guys...
Old May 21, 2003 | 11:17 AM
82-T/A [Work]'s Avatar
I don't know WHY you'd want to get rid of a MAF system for a Speed Density system. My 87 Fiero uses speed density. Pontiac LOVES Speed Density systems, and they use that in any application that they can get away with where it doesn't interfere with production of another vehicle.
The SD on my car uses the Vehicle Speed Sensor, in conjunction with a MAT sensor, and a MAP sensor along with the TPS of course.
However, a MAF system is much easier to deal with when modifying an engine. Seriously.. it can measure the amount of air flow comming into the engine, and therefore convince the computer to send more fuel MUCH easier than an SD system can. MANY Fiero owners try to convert to a MAF system from a 3.1 Camaro / Firebird.
If it's broken, just fix it.
Old May 21, 2003 | 04:59 PM
there is a fine line between (easy to tune MAF) and (less restrictive) Speed Density
as an example, somebody who might stick with a MAF sensor: car is daily driven, and the mods that are done to it are not too extreme, say like a slightly bigger cam and a little headwork AT THE MOST
those who convert to Speed Density usually have a need for more air and in turn, they take advantage of every possiblilty to free the air path; this person prolly has hi-performance heads, worked bottom end, and a large cam........cars not really a daily driver, its meant for performance
Old May 21, 2003 | 05:01 PM
Tom, i'm honestly not sure, because i stopped following the V6 thing awhile ago
part of me wants to say "yes" that the gen II fwd cars use the 730 ECM
another part of me wants to say "no" because they use DIS and i am not sure if that is supported by the 730 ECM
although i am learning more towards "yes" the gen II FWD cars use the 730 Speed Density ECM
BumpaD82
Feb 26, 2016 02:57 PM
Jk_Under
Sep 8, 2015 08:13 AM
IROCZ1989
Sep 4, 2015 11:54 AM
