T5 oil weight ?
Old May 27, 2003 | 11:20 PM
gloin85's Avatar
T5 oil weight ?
my transmission clanks a bit when I put it in reverse.
most the time it wont if I shift to third / then into reverse.
I know the current fluid in there is the automatic red colored stuff.
Just curious what weight oil should be put in these transmissions and if I can get it at a local auto-zone or pepboys shop.
Old May 28, 2003 | 12:08 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
It's just straight up Dexron III automatic tranny fluid.
Old May 28, 2003 | 10:23 AM
gloin85's Avatar
hm ok. I was pretty sure someone told me it was 90w. do you know the weight of the Dexron III automatic tranny fluid ?
Old May 28, 2003 | 11:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It's not too heavy, about 9-10 lbs a gallon.
RBob.
Old May 28, 2003 | 01:21 PM
Doward's Avatar
Do not use standard 90w or 80w or any weight oil other than auto tranny fluid in your stick shift. You will blow your synchros!
Old May 28, 2003 | 01:43 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
90w should be kept for the rear end. Listen to these guys and keep the red dexron III in there. Have you considered the possibility of a bad U joint? If one is bad, you can get that clanking sound you described.
Old May 28, 2003 | 01:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
RBob.
I'm sure the people in my office are wondering why TomP just choked on his coffee...
Old May 29, 2003 | 08:25 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Just in reverse? I had the same issue a few years ago, and it turned out to be the posi differential plates making noise. The rearend fluid was changed to heavy duty synthetic, and the noise has never returned...
BTW, 90W stinks like ***... Try not to get any on you!
Tom, how's the coffee?
Old May 31, 2003 | 12:31 AM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
How often are you supposed to change out the fluid in the tranny?
Old May 31, 2003 | 12:35 AM
Doward's Avatar
I replace mine every rebuild or clutch change
Old May 31, 2003 | 02:03 AM
It's a general recommendation (at least where I live) to change trans fluid every 12k miles or so, but that's on an automatic. I would imagine the 5 spd would be similar, it's what I follow for mine, and my 5 spd hasn't given me any troubles.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
