Has anyone used 4thgen accessories on 3rdgen?
Old Jun 6, 2003 | 07:20 AM
IndyTruck's Avatar
I'd like to use the 4thgen 3.4 serpentine belt setup on my 85 when I put in the 3.4. Has anyone tried this?
I reckon the 4thgen has a better alternator, which would be cool to have, but mostly I just like the brackets and serpentine. The 2.8 has one serpentine and one V belt.
thanks
kevin
Old Jun 6, 2003 | 07:53 AM
IndyTruck's Avatar
hmmm........ Took a quick look. AC compressor may be different. The AC in the 85 works, so if it's different I won't mess with it now.
But I would like to do this sometime if possible.
cya
kevin
Old Jun 6, 2003 | 09:44 AM
KED85's Avatar
When one does an engine swap, it is custom, so ya can do anything ya want.
That said.
I did my initial swap as the dummy system.
I used what originally worked. Swapped over to the 3.4 mill.
That does require to do what I suggested in my thread. Use original timing cover, etc.
PLUS
The alternator.
Ask me about overpowering things in the car due to alternator spikes. Keep the original Alternator as teh cars system is designed for that output (try saying fried ICM perhaps. I fried 6 ICMs!)
That said, if ya can figure it out adapting the pulley set up, let us know.
Even on my Blazer, I kept the old pulley set up. Again, keep it simple.
What I wrote is pretty much what it eventualy boils down to.
Spend the exrta effort time on upgrading or rebuilding original 1985 stuff, to perform like day one.
What ya truly modify is the original "Y" pipe. Use the 1995 "Y" pipe & mold to fit the 1985 chassis. I still have mine & will be modifying mine shortly. I want the extra HP benefits for the money spent. I have used the 1995 issued AC Delco CC on my 1985 car. Fit perfectly, operates proper, too. Will be sure when I pass smog, shortly.
Enjoy the research!
Old Jun 6, 2003 | 01:15 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
so, yoiu also want to delve into the world of the 2.8-3.4 Swap Boogie ver. 2.0
check out the link in my sig, page one has the pics you want. :rockon:
Old Jun 6, 2003 | 01:59 PM
IndyTruck's Avatar
Cool, thanks! You don't have AC tho, do you?
Looks good!
kevin
Old Jun 6, 2003 | 03:00 PM
Engine: 5.7 / 7.4
no A/C because:
a) the compresor was damged when I got it,
b) WOuld have to get new or custom lines since the location is different. mabe yo could splice/connect the 3.4 lines to the firewall?
Old Jun 6, 2003 | 03:02 PM
IndyTruck's Avatar
From looking at TomP's pictures, it seems there is a crossmember or something on the g3 that would interfere with the g4 compressor. What do you think?
thanks
kevin
Old Jun 6, 2003 | 09:57 PM
Engine: 5.7 / 7.4
http://www.thenebula.com/carpics/pics2/IMAG0027.JPG
http://www.thenebula.com/carpics/pics2/IMAG0028.JPG
if I still had the compressor, I could tell for sure, but looks like it might be close.
edit: Dale could've answered this for us if he put his 3.4 in the proper vehicle :sillylol:
Old Jun 6, 2003 | 10:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The Ac compressor fit fine in my truck in its stock 3.4l form, very close though.
While doing the swap, I found the camaro uses a wider frame rail system then my s10, so it just might fit.
I still do not have my ac plumbing done. I do know that the hose end is diff diameter then the one on the aluminum canister thingie. I am going to have to find a shop that does full custom work.
Old Jun 9, 2003 | 12:52 PM
Engine: 5.7 / 7.4
I loked at a 93 camaro this weekend, the a/c compressor is small, the bracket tha holds it is abot 50% of the diameter. yes it will be close, but I belive it will fit.
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
evilstuie
Sep 24, 2015 02:31 AM
Camaroguy2
Sep 22, 2015 08:22 AM
Mdenz3
Sep 17, 2015 08:36 AM
