bought my bird!!!
Old Jun 16, 2003 | 05:04 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
bought my bird!!!
so, i looked at the car. the engine was not new, it was rebuilt. it does have a new clutch. the t-tops dont leak. engine runs great, oil was so clean you could make a salad dressing with it!!! also, engine is not stock. it has been bored by .03 it has an aftermarket cam. and flat topped pistons. new radiator, new harmonic balancer, new throw out bering. suspension is heavily modified!!! so tight you can feel the tires flex before you get any body roll. sway bars are tight!!! springs are stiff as can be, i think it might actually be to stiff.
now for broken stuff:
headliner needs replacement. drivers side mirror is broken,( no adjustmet, flops in the wind), no antena, shocs on hood and hatch are bad. rear cargo straps missing. t-top bag missing. center console has sun damage, doors rattle, has original tape deck w/ original speakers. right turnsignal does not blink. drivers side window does note quite seal, cruise control busted, windshield washer fluid pump no work, think thats it.
other details: car has ugliest rims i have ever seen on firebird, will post a picture tomorow or next day. seats have always been covered. are in like new condition with exeption of a burn in the back one and a tear in front drivers side. has split folddown rear set and no cargo cover. paid $2,000. has 124,000 miles. 11k since re-build. have recipts for clutch, new tire, radiator, and a buch of other random parts (just shows numbers). think thats it. anny other questins ask
Old Jun 16, 2003 | 05:22 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Sounds like you got a good deal, if the suspension is already set up... take pics. Look under the car, and post pics of the rear end, front end, all over. Get a pic from underneath, too! Maybe one of us can see if it's just new OEM suspension, or actual upgraded suspension!
Sounds like a good score!
Old Jun 16, 2003 | 05:38 AM
Xophertony's Avatar
Axle/Gears: n/a
i work monday 2-1am (yea thats 11 hours!!!) but off tuesday, my car will have my complete attention. i will have pics up by 5pm on tues (western/mtn time)
by the way, ither our cars handling KICKS ***!!!! or its aftermarket, cause damn....... drives like... um... need analogy....really good.
oh, got one,
hugs the corners like it was glued to the ground.
Old Jun 16, 2003 | 05:40 AM
Doward's Avatar
What size tires on it?
Old Jun 16, 2003 | 05:41 AM
Xophertony's Avatar
Axle/Gears: n/a
stock
i think..... i will find out tomorow
Old Jun 16, 2003 | 05:42 AM
Doward's Avatar
lol... no, I mean actual tire size -
I know just going from my stock 215/65/15s to IROC 245/50/16s made a HUGE difference in corner huggin!
Old Jun 16, 2003 | 05:43 AM
Xophertony's Avatar
Axle/Gears: n/a
uhhmmmm... i will admit i do not know alot about tires
width/sidewallhight/wheel size?
Old Jun 16, 2003 | 05:47 AM
Doward's Avatar
Actually, its -
Width/Aspect Ratio/Rim Size
Old Jun 17, 2003 | 04:32 AM
Xophertony's Avatar
Axle/Gears: n/a
so i am driving a coworker home today and my car botoms out ona speedbump!!!! what am i driving a civic here? in adition to having tight suspension, my car has been lowered. i will post pics tomorow.
also, if anyone is looking for a jeep charokee w/ straight six....
Old Jun 17, 2003 | 04:54 AM
Xophertony's Avatar
Axle/Gears: n/a
newbie question!!!
what are rollers/rockers? i always thought rockers wer those things that moved the valves on an engine without an overhead cam.
also:
i know the crank shaft is the one the pistons conect to. and prety sure the cam shaft is the one that hits the valves to make them go down int the cylinder. ut i am unclear as to the term "floating a valve" is this when a valve, for some reason stays open and gets smacked by a piston causing a chain reaction destroying your engine?
Old Jun 17, 2003 | 09:44 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Not to rain on your parade, but it sounds to me like you're runnin' on shot shocks and struts. My car used to ride like that. I always thought "well it's a sports car, not a Cadilliac so you can expect a rougher ride" well ends up after I took my shocks out that they were the stock ones and COMPLETELY shot. My car used to always bottom out on everything, and actually becuase of them being so shot it actually droped the ride height of my car overall. I bought new Bilsteins and now it rides sweet and I hadly ever bottom out. (I still slow down, I still don't drive an SUV here...) But you get the idea.
Definately take some pics and post them and we'll all be able to most likely identify all the parts. Congrats on gettin' a thirdgen!! You'll never regret it!
Old Jun 17, 2003 | 10:54 AM
Xophertony's Avatar
Axle/Gears: n/a
you know whats messed up?.... the main reason i convinced my self to loose the SUV was becouse i did NOT likle slowing down for speed bumps. that charokee has tighter suspension for towing you hit a speedbump fine w/front, but the rear will get air.
Old Jun 17, 2003 | 04:41 PM
Xophertony's Avatar
Axle/Gears: n/a
Got a few outside pics
Old Jun 17, 2003 | 05:46 PM
Doward's Avatar
Few? I only see one! More pics!
Old Jun 17, 2003 | 05:50 PM
Engine: 346ci LS1
Transmission: MN6
Xophertony - Looks nice, but we'd all love to see more pics! Only thing to remember is don't attach more then 3 pictures per thread, they put in a new policy about that. I'm not sure if it applies to only the appearance board or not though...
Edit: Here is the tread I am talking about
Old Jun 17, 2003 | 07:10 PM
Xophertony's Avatar
Axle/Gears: n/a
ok here are three more pictures, and for the record, i host my pictures, i waste angelfires server space, not thirdgens!!
also, yes i know. my wheels suck. i will be getting some turbocast rims asap
Old Jun 17, 2003 | 07:16 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
man u were right about those rims
looks like a sweet clean ride though, very nice
Old Jun 17, 2003 | 07:21 PM
HeavyBreathinRS's Avatar
Car: 1990 RS
ok...I just picked up an '84 GTA 305 with a T-5 that runs, great interior, power mirrors, windows, locks, cowl induction...all work.
Total price....$350.00 CDN...about $200.00 US...all I wanted was the tranny...now it looks like it'll be a his'n'hers....with a 400 stroker in the TA...
Old Jun 17, 2003 | 07:36 PM
Xophertony's Avatar
Axle/Gears: n/a
start your own thread, this one is so i can brag
seariousley, way to go dude. how did you manage that?
Old Jun 17, 2003 | 07:42 PM
Doward's Avatar
DUDE!! THOSE ARE 15x7 SNOWFLAKES!
They suck? Dude, i should smack you for that! Those are awesome rims. 2nd gen 'bird rims there man. Tell you what, I'll swap you some 15x7 Camaro 5 spokes for 'em!
Old Jun 17, 2003 | 07:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Them are some smokie and bandit rims. And I think they look quite decent on it. Better then some of the others I have seen. However, they do need some cleaning up.
Old Jun 17, 2003 | 08:49 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Nice, your right tho, the rims are ugly++
I dont even think cleaning them will help Leave em to the 2nd gens.
And your front ride hight looks a little low... bad springs and shocks maybe. (like mentioned earlier)
Old Jun 18, 2003 | 12:00 AM
Doward's Avatar
Anyone thought of cut springs, with worn shocks? That's my bet.
You think those snowflakes are ugly? Man, where do you think the design for the 16x8 crosslace T/A wheels cam from?
Personally, I'd rather have the crosslaces, since you can get better tires in 16" A good clean/strip/polish, and those wheels would look sharp.
Old Jun 18, 2003 | 12:13 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
nice!!
Old Jun 18, 2003 | 02:44 AM
F585's Avatar
Love the rims
Old Jun 18, 2003 | 03:39 AM
Xophertony's Avatar
Axle/Gears: n/a
post a pic of the camero rims if i like i might consider a trade. if not i could alaways convert the hubs to four spoke honda pattern and get some gold knock offs w/100 spokers.
joking^ what i realy want are the turbocast rims. those are sweet
Old Jun 18, 2003 | 08:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Haha yeah I was just going to yell "The snowflake rims!!" but Doward beat me to it. Just go to http://www.ebay.com and do a "power search" for "snowflake wheels" for completed items... those things sell for a hell of a price.
Got a friend who got an '82 s10 pickup with a 350 dropped in, he was laughing at the rims- I was like Hey, the snowflakes!!
[edit] Forgot about the topic of the message. Very nice looking car; the body looks perfect.
Old Jun 18, 2003 | 02:54 PM
Xophertony's Avatar
Axle/Gears: n/a
you know whats messed up? there is no clearcoat on the paint!!!! somone just sprayed it. great paint though.
Old Jun 18, 2003 | 02:59 PM
Xophertony's Avatar
Axle/Gears: n/a
Old Jun 18, 2003 | 03:20 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
those are decent, but i like these alot more:
these are also kickass:
im going to get either the formula or the firehawk wheels when i get my turbo setup complete.
Old Jun 18, 2003 | 03:39 PM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
Heh, some previous owner did that to mine as well. So I have to drive really slow at an angle over them bumps. That and I don't want to raise the cat anymore.
Old Jun 18, 2003 | 08:06 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Sounds like you got a 1 stage paint job on her. Thats what I did to my 85. Now you can wet sand the car without worrying about sanding thru the clear and same goes with buffing as well
Old Jun 18, 2003 | 09:20 PM
Doward's Avatar
Wetsand, buff, then clear coat it!
Wax it every week, and she'll shine for ages!
heh... sorry TomP...
Now, the rims on your car now are the standard snowflakes. 15x7" The gold ones you posted a pic of, are the WS/6 15x8" rims. Notice the lip on the gold ones, that you don't have?
Yes, those snowflakes can go for a pretty penny. My 15" Camaro rims look like these -
http://i.b5z.net/i/ui/74360/i/Z28wheels.jpg
I don't have 4 good center caps tho... not that you'd want them - they say 'Camaro'
Hey TomP, you ever get people that call the honeycomb's snowflakes, and vise versa? I get it all the time...
Old Jun 18, 2003 | 10:05 PM
KED85's Avatar
I believe you are referring to the wheels style I have on mine.
I'm envious, pretty ride.
I can't wait to fix the front end on my Firebird.
I already fixed the back bumper, was easy. Replaced it!
You want to go to www.slponline.com
Street Legal Performance
has your wheel option at a GREAT PRICE!
Those snowflake wheels are worth a VERY PRETTY PENNY.
Even size 15 x 7.
Yeah that's a wonderful car those belong on!
Ugly, well... No, not at all.
If ya saw the total Firebird package, those wheels are the right touch.
Eagle One makes a great wheel cleaner for those wheels.
Old Jun 18, 2003 | 10:57 PM
Doward's Avatar
You know Karl... you totally hide your wheels in your pic Gonna have to get another to show them wheels!
Old Jun 18, 2003 | 11:21 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I think the snow flake wheels look good on your car. A good trick if ya cant get them to shine is to paint them with DH1606 and lightly sand the outside edge back to aluminum base then clear coat them. Does work quite well and lasts a long time. Aftermart you cant beat the Hellcat series. I can tell the right side is lower then the left, id check the struts and springs. Same shade of white as my bird also Dupont single stage pre-mixed.
Ked man, you need a spolier you back half is naked
Old Jun 19, 2003 | 05:05 AM
Xophertony's Avatar
Axle/Gears: n/a
those gold wheels i posted are stupid. i would never say bling bling if i was not joking. also the highest price i saw on ebay was 400 for all four of the snowflake rims, is that good?
so you can clear coat a car thats allready been painted... my dad told be to ask yall. while i am at it should i add another coat of white and do some rust clean up. there are two spots where i have body rust, one is on the right cquarter pannel where it meats the door ( door not scraping i already checked.) and the other is where the antena mount used to be, is there anny cap or plug i can get to seal that up? also. how much do turbocast rims go for? i could not find them at that website.
these are turbo cast rims:
Old Jun 19, 2003 | 05:31 AM
Xophertony's Avatar
Axle/Gears: n/a
newbie question!!!
also:
would still realy like to know all this, so far up i think everyone missed it
Old Jun 19, 2003 | 08:17 AM
KED85's Avatar
SLP sells the factory optional wheels take offs with tires of the 4th gen cars for DIRTCHEAP!
I really like the car the way it is, minus spoiler.
I am seeking a center section, taillight panel, tho.
One day after I retire again, I'll take a better pic of the Firebird at the beach. Maybe in 4 more weeks or less.
My Firebird wheels are the factory optional turbo styled wheels.
Old Jun 19, 2003 | 03:27 PM
Xophertony's Avatar
Axle/Gears: n/a
no they are not, if you look at my atached picture you will see what TURBO CAST rims look like, the picture of your firebird does not have TURBO CAST rims. i hate to nitpic, and i do like your wheels. but they are not what i am looking for.
Old Jun 19, 2003 | 04:37 PM
KED85's Avatar
Your other pictures do not show up.
First two wheel pics, do.
My 15 x 7 Turbo wheels are made by Superior Industries for Pontiac Motor Division, as are the 16" x 8" size of the first pic of yours. They were optional on the Firebirds. On the Trans Ams I believe. I use those WS6 Center caps on my wheels, looks pretty.
IF ya got another name for my wheels, please say so.
I used to call them, Pinwheel style.
Yet, turbo is probably correct name for my factory optional ones.
My factory build sheet calls them out as the Y99 Wheel package combined with the F41 suspension
IF ya know another name, please say so, love to hear it!
I'm seeking the Firebird White Book & the 1985 Firebird sale brochure for the fun of it facts.
I found my 85 Firebird factory build/birth sheet under driver side, back seat cushion.
Not saying yours'll be there, but who knows.
BUT SLP has brand new F body Firebird take offs for about $400-$600 & they look like other wheel shown first time.
Old Jun 20, 2003 | 05:58 AM
  #42
Xophertony's Avatar
Axle/Gears: n/a
i have a name for your wheels, ugly. ha ha. i joke. there not my favorite fbody wheels, but i like them more then mine. maybe your wheels are called turbo wheels, the ones i am refring to are called turbocast wheels, not much of a diference. i did not see the turbo cast rims on slp.com. if you could help me out or give me a direct link to them specifically that would be awsome. thanks for your help
Old Jun 20, 2003 | 07:35 AM
  #43
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well at least you guys have 15+ rims and not the 14's my car was cursed with. Even though my wheels are nicer then all but one other style in 82 IMO.
Yes you can clear coat a single stage paint job but beware some paints can react bad to clear coat or vise versa and it will ruin the paint. Ive seen some where the clear coat actually bubbled up the paint under it and some where the clear would not stick and durring the cure scrunched up like a wrinkled paper bag.
Old Jun 20, 2003 | 10:28 AM
  #44
Doward's Avatar
You talking about the Knight Rider turbocasts?
http://www.knightreplicas.com/how_to...cast_rims.html
Old Jun 20, 2003 | 04:06 PM
  #45
Xophertony's Avatar
Axle/Gears: n/a
yeah, the knight rider turbo casts, thats what i want on my car
Old Jun 21, 2003 | 06:22 AM
  #46
Xophertony's Avatar
Axle/Gears: n/a
another newbie question. what is the intake plenium and what does it do???
still::
Old Jun 21, 2003 | 10:58 AM
  #47
Engine: 346ci LS1
Transmission: MN6
How a camshaft works.....
Just a little information for you! Not saying that you don't already know, but I find it interesting!
Old Jun 22, 2003 | 04:22 AM
  #48
Xophertony's Avatar
Axle/Gears: n/a
wow. my car looks so much better then this other guys car. my car may not have "cool" ground affects or "NAWZZZ" but at least it is in good taste
EDIT: pic a bit small caption reads
otomosprime: bumblebee did the diceptabots do this to you?
bublebee: no i fell asleep in mexico and i woke up like this!!
Note: i do not mean to offend annyone from the country of mexico. in my opinion it should read "in front of a R**i**c**e**r bar"
Old Jun 22, 2003 | 04:27 AM
  #49
Xophertony's Avatar
Axle/Gears: n/a
also, if somone could please explain to me what "floating a valve" means. i know soone knows, tomp? a good2.8 you guys are smart, help a guy out?
86IROC112
Sep 7, 2015 01:37 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
Catcher55
Aug 15, 2015 07:08 PM
drathaar907
Aug 10, 2015 07:44 AM
