Starts then immediately stops - any ideas?
Ok, heres my problem.
My car will start, then in less than a second it will stop running. I cant really even say that it runs at all, just starts then stops.
I have two Camaros, both with the same problem!
Any ideas would help.
thank you
thank you
Car: 1984 F41 T-Top
Transmission: 5 speed
not 100% sure but it could be that your timing is off or the engine is flooded.
If flooded I would remove all spark plugs, crank engine for a few seconds, wait a few minutes, then reinstall spark plugs. While spark plugs are out clean the tips. I had to do this and my car started right up.
Got any error codes.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Double and triple check the ignition. Also see that the injectors are injecting... could be a lot of things,
Is the engine throwing any codes?
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Clogged fuel filter? Bad fuel pump? Check fuel pressure.
Bad spark? Check spark.
Bad injectors? Smell tailpipe. (Crude, but somewhat effective, and far better than ripping the plenum apart)
Bad MAF/MAP/IAC/Other electronic components? Check for codes.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
A bad pickup coil (inside the distributer- not the ignition coil) will cause a motor to only start breifly then die- It is often mistaken for a bad fuel system(a.k.a.- bad fuel pump, injectors, regulator etc.)
I'd go over the ignition first. Could it use a Major TuneUp anyway? If so, yank the distributor, rebuilt it, with new ignition components, and do the Major TuneUp.
See how it goes then.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
check the vacuum line for the power brake booster. If it's come off, you'll have sooo much vacuum loss that the motor will immediatly die.
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
i have the same problem with mine especially when it is cold out..i hate the winter time
.....the only way i can get it to stay running when its cold out is holding my foot on the gas pedal & then sometimes it will be ok but other times its not....but then again of course it has the d@mn maf
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
MAF's are extremely touchy.. My friend had an 86 Camaro that would would periodically start, then stall...start, then stall...over and over again. It was a faulty MAF.
I was hoping I'd never have to experience the MAF's, since my Camaro had a 3.1 (non-MAF motor)....but then I got the 302. So far, so good. MAF's are too expensive to have fail frequently.
Car: '87 Chev
Engine: 60*V6
Car: check
Engine: check
Transmission: check
Re: Starts then immediately stops - any ideas?
thank you
thank you
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
