Can't... decide... what... to... do!! ARGH!
Old Jul 2, 2003 | 03:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey if you guys could visit my message at the suspension/chassis/brakes forum and vote on my poll and/or post your opinion, I'd appreciate it! Message is here: https://www.thirdgen.org/techbb2/sho...hreadid=188593 I don't know what to do with my 250,000 mile original front brake calipers.
Old Jul 2, 2003 | 09:57 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Just buy refurbished ones from Pep Boys or whatever, they arent that expensive, if you return your old ones to them they usually give you like 10-20$ off. (Each)
Old Jul 2, 2003 | 10:05 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
secret option number 4...UPGRADE!!! Get spiffy new ones from somewhere reputable...<insert drool here>
Old Jul 2, 2003 | 11:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I fear other forums AZ has thenm for like $10. calipers. lifetime warranty.
Old Jul 3, 2003 | 12:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, but see, I'm not worried about cost!! Man, nobody on thirdgen.org understands that...
I want to know what's better to do!!
I'd prefer to rebuild my own... but the idea of rust has taken hold... I can only scratch out rust with sandpaper. A rebuild company can actually hone out the piston bore and re-polish everything... I can only play with 400 grit sandpaper.
I think I'll call my local "real" parts store and see what they can get for me tomorrow. Should be fun to change the brake hoses and calipers Friday morning, or, Sunday afternoon.
Old Jul 3, 2003 | 02:19 AM
Really-Slow-RS's Avatar
If you're not worried about cost, go with some 4-piston Wilwood calipers, or something along those lines.
Old Jul 3, 2003 | 10:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL; I should figured that'd happen... okay, smart-*** I mean not worried about cost between a rebuild kit and already-rebuilt stock caliper. I can't justify getting an exotic front brake setup for my car when it's just a v6.
Sheesh you guys are picky!
[edit] I've come to this conclusion: I'm going to hunt down new front brake hoses today. I'll worry about calipers next week. I hate doing work twice but hey, it's the 4th of July, I don't want to spend 2 hours in the garage Friday morning. I'd rather just spend 1 hour for the front brake hoses; most of which should be trying to get a jack under my now-lowered car. Can't slide the hydraulic under the front anymore. I've gotta raise up one control arm using an old-school (mid-70's) "screw" jack- looks like a hydraulic but you turn a center screw which lifts the car. Then I can get enough room to slide the hydraulic underneath.
When the car's in the air, I'll also give all my new toys another lube job, change the oil, and check the torque of the LCA bolts.
Old Jul 3, 2003 | 11:45 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Either do them yourself, or get some rebuilt ones from Autozone or whatever. If you have a shop do 'em, and they F them up, you have to jump through hoops, and odds are - they'll get F'd up again.
If you do them yourself, you know they are done by the book.
If you get some from AZ, you can bring 'em back, and prolly get a lifetime replacement on 'em!
Old Jul 3, 2003 | 04:42 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
wow tom, u need a lower jack..lol my big 3 ton jack sits at 3" and fits under my car nicely, if your car is lower than 3inchs at the control arms then yikes, that makes your front at like what 2 1/2-2" maybe lower?
Old Jul 4, 2003 | 03:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If I think of it, I'll try to get some kind of measurement for height for ya.
Old Jul 4, 2003 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Okay, here's the scoop on the measurements-
Crossmember-to-ground: 4 inches
Bottom of air dam to ground: 5 inches
Height of tom's 2.5ton floor jack: 5 inches
Old Jul 4, 2003 | 01:22 PM
Doward's Avatar
ROFL! My buddy's 5.0 '95 Stang did that after lowering the car about 2"....
Solution -
Put down some 2x4s, and roll up onto them (set 'em as tho they were running front to back, or like you'd roll up on a lift) and then you should have just enough room to get the jack under there!
Old Jul 5, 2003 | 09:58 PM
KED85's Avatar
There are several floor jack that are very low.
Sears also has them, so will Harbor Freight.
gta892000
Sep 16, 2015 12:37 AM
GoldenSwordZ28
Feb 27, 2002 09:55 AM
Demon Z28
Pacific Northwest Region
32
Jun 25, 2001 08:05 PM
Jim85IROC
Car Audio
May 16, 2001 10:42 PM
RICHRAD
Carburetors
May 11, 2001 09:57 PM
