Help Tonight, PLEASE!!!
Old Jul 8, 2003 | 05:47 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I posted this in trans section (proper section) but I need all the help I can get tonight, PLEASE!!!
https://www.thirdgen.org/techbb2/sho...hreadid=189838
Old Jul 8, 2003 | 06:07 PM
Dale's Avatar
Engine: 350 S-TPI
ttt, your helping, please keep info coming
Old Jul 8, 2003 | 06:17 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Different position of the shifter. Are you sure the Fbody tailshaft will work?
Old Jul 8, 2003 | 06:23 PM
Doward's Avatar
There is a bright side - all you need is an S10 tailshaft, to mount it into your truck...
Old Jul 8, 2003 | 07:58 PM
Dale's Avatar
Engine: 350 S-TPI
tail shaft n splines all the same.
I need the shifter futher back anyway.
I'll just cut the mount off the cross member, then re-weld it at needed angle and height.
Old Jul 8, 2003 | 08:05 PM
Doward's Avatar
Be careful... it's like a pot metal crap... might not like being cut/welded
Old Jul 8, 2003 | 09:13 PM
Dale's Avatar
Engine: 350 S-TPI
Not the tranny, the cross brace on the truck.
Old Jul 8, 2003 | 10:52 PM
TravisZ28MAXX's Avatar
Car: 1992 Z28 and 1988 IROC-Z
Engine: both L98s one with SD and one with MAF
Transmission: both 700R4s
ok I saw this post and had to ask my own question. Im using a T5 trans attached to a 3.1 engine, not going in a GM application, could I re-clock the trans to the straight up and own position and it will work fine?the tilt of the trans is a little bit of a concern because the trans currently in the car I believe mounts strait up and down, basically I didnt want to have the shifter in my lap in second gear.
Old Jul 9, 2003 | 10:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The tilt had something to do with the f-bodies. I read it in one of the car magazines once... damned if I could find the article in that pile! I -think- it had to do with the way the trans needed to fit? Anyway, you'd be fine un-doing the tilt, the trans worked like that (no tilt) in other cars...
Old Jul 9, 2003 | 11:05 AM
cool cool i wasnt to interested in having the shifter in my lap in second gear.
Old Jul 9, 2003 | 11:15 AM
Dale's Avatar
Engine: 350 S-TPI
Mine is now vertical. I am just going to have to redo the frame mount part.
S10 shifter went in it fine too
Old Jul 9, 2003 | 01:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Yeah, right? "Is that your shifter or are you just happy to see me?" And forget about powershifting- ouch.
Old Jul 9, 2003 | 03:29 PM
Dale's Avatar
Engine: 350 S-TPI
Tomp, It's got buckets, so thats not a problem.
Now in the bed of the truck, thats another story
Bubbajones_ya
Jul 6, 2024 08:32 PM
1MeanZ
Dec 18, 2015 05:39 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
Scorched1984
Sep 15, 2015 03:42 PM
