RTV on the plenum for a last resort?
Old Aug 22, 2003 | 07:40 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Hey guys , in trying to replace the tb to plenum gasket i cracked the plenum so i need to buy a new one (junkyard) so i went to napa and tryed to order the appropriate gaskets and they dont carry the tb to plenum gasket for my car .. and cannot order it. I have the old one but it had a vac leak. I need to send my car to be smogged monday so i cant wait to order one. If i rtv both sides of the old gasket can i reuse it. Id eventually get the correct one. Which type of rtv should i use? I need to reuse the gaskets in between the plenums too.
I need help quick , thanks
Old Aug 22, 2003 | 07:49 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Autozone, under Gasket, Throttlebody p/n 96-3001 $8.00
Old Aug 22, 2003 | 08:09 PM
heh sometimes i forget autozone exists with napa and car quest down the street, ill try that tommorow
Old Aug 22, 2003 | 08:50 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
My autozone guys are either stupid or little b*****s, the only way I can get a that gasket outta them is to buy the entire upper half gasket set....I've resorted to just cutting my own, much cheaper.
Old Aug 22, 2003 | 08:56 PM
Engine: 5.7 / 7.4
I used to work for AZ, but since non of ya'll live around here, you lost some qaulity service
If any around the La PLata MD way, my bestest buddy was Just made manager there. he knows sheesh loads of sheesh about the mustards, but then nobodies perfect
Old Aug 22, 2003 | 09:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If they dont have the Gasket in stock use Hylomar or grey silicone (AKA Yamma seal and a few other's). Hylomar is aircraft sealant and a very fine spread of it will work, works well enough to use on the jet liners. The grey silicone is also good, much better then regular RTV, forms a hard seal and doesent leak. All avalible at O-Zone.
Hey Project, move to Colorado! I need a new Commercial Rep, I'm getting the old one demoted and or fired monday.
Old Aug 22, 2003 | 11:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I like the hi temp copper RTV.
Old Aug 23, 2003 | 12:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Buy a roll of flat gasket material (black) and an X-acto knife and cut your own.
Felpro makes a kit containing every intake gasket but it's about $35.
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
19
Oct 6, 2015 12:27 PM
italiano67
Sep 22, 2015 08:42 AM
