Coolant dump point ...?
Old Nov 7, 2003 | 12:31 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Need a good location to route the turbo's waste coolant... I'm thinking tapping/welding a 3/8" hose barb onto the thermostat housing.. anyone have a better idea?
Old Nov 7, 2003 | 05:09 AM
ede's Avatar
ede
nit sure how you have it all arranged but i tihnk i'd route it to whatever would be the shortest distance, maybe back to the intake. personally i don't like the looks of extra lines or senders on the t stat hat. you can buy one already tapped for less than 10 dollars. and save the time and effort of doing it yourself
Old Nov 7, 2003 | 10:34 AM
TechSmurf's Avatar
Engine: LS1, Scrap
I don't like the looks of extra crap anywhere in an engine bay.. but the turbo kinda shoots that right out the window anyway
I think I'd just drill/weld the barb before paying for one.. tools are readily available..
Old Nov 7, 2003 | 11:07 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What about the heater core plumbing?? You have a come and go for it. Will keep it low so you also get gravity helping you on the dump.
Old Nov 7, 2003 | 11:46 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Does the heater return actually have a pull to it, or is it just being pushed through by the inlet force?
Old Nov 7, 2003 | 01:19 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
heater return is most likely being pushed. On the Poncho 400, for example, the heater return goes into the pass head.
edit: or at least mine did.
Old Nov 7, 2003 | 01:29 PM
Dale's Avatar
Engine: 350 S-TPI
So if its being pushed thru, that wont work because it would try and push it back into the turbo. Didnt even think of that.
Damn, I tryed
Old Nov 7, 2003 | 01:31 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i donno about you guys, but id dump it either into the upper radiator hose, or the radiator itself........ thats where hot coolent should go anyway, right?
Old Nov 7, 2003 | 02:32 PM
TechSmurf's Avatar
Engine: LS1, Scrap
That's why I was thinking thermostat housing...
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
corey8084
Sep 17, 2015 02:56 PM
