3100 series injectors...
Old Dec 17, 2003 | 11:08 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Quetion, are the 3100 series injectors on mid 90's FWD GM motors adaptable to work on the 2.8L ? I got a 3100 series motor at the shop, and since I'm getting ready to port the upper/lower manifolds, I figured Id Swap injectors too (I've been running lean...). The motor in question was used in all kinds of GM cars, they are quite plentiful in my area. The Houston area Has the emissions Dyno Test too, would that kill me?
Old Dec 17, 2003 | 11:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
if you're running lean, you might wanna check your 02 sensor. or your injectors may be getting clogged up or something, just putting bigger injectors in probably will cause you problems.
Old Dec 18, 2003 | 07:50 PM
FbodTrek's Avatar
I've been ALL through the car dude...The only thing left is lean injectors (by flow chart anyhow...). I was just wondering if anyones had any luck usingg them.
Old Dec 18, 2003 | 08:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
No, 3100 injectors will be to big, make it run overly rich.
Will they fit in the holes? YES
Old Dec 18, 2003 | 09:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Could just put in an adjustable fuel reg and crank the pressure up / the NO2 kits for our cars come with a restrictor valve that reduced the return flow and raises the pressure when you hit the gas.
Or maybe you reg is failing???
Your pump has enough PSI but after the reg the injector side PSI is down???
We run at 130-145 line psi what is it at the injector / what is the stock reg set for???
Old Dec 18, 2003 | 09:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Might wanna run a couple cans of seafoam [napa] through the tank to clean up anything in the fuel system.
Old Dec 18, 2003 | 09:54 PM
Dale's Avatar
Engine: 350 S-TPI
the vacume line to the regulator could be cracked, or gotten knocked off.
I've had that happen twice in past month
Old Dec 19, 2003 | 02:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Huh? I take it 3.1 injectors aren't the same size as 3100 injectors then?
Old Dec 19, 2003 | 03:02 PM
Dale's Avatar
Engine: 350 S-TPI
tom, they are wanting to know if they will fit on a 2.8
It will go in the hole, it will spray, but it will spray to much.
Injectors in 3100 and 3.1 are same as I know.
Old Dec 19, 2003 | 07:37 PM
FbodTrek's Avatar
.....Anyhow....Hey Tom, have YOU tried running 3100 series injectors? I imagine the computer would automatically compensate for the extra flow (Tom, correct me if I'm wrong??) I could care less about running a little rich, THATS the point. I WANT the car to run a little rich (if thats even possible...).
You see, the odd thing about my motor is that it is showing a 14.7:1 AF ratio, but I still get the code 44. It has nothing to do with sensor input, The only things left to cause it are mechanical. If I run it hard when it's lean, I'll burn a valve (REALLY don't want to rebuild the heads...). Anyways, anybody who HAS used 3.1 injectors, talk to me. Thanx
Old Dec 19, 2003 | 10:28 PM
Dale's Avatar
Engine: 350 S-TPI
if you look at the last post tomp created, you will see that he is asking the same as you. So we can assume he hasnt.
I installed 3.4l injectors in my 3.1l engine. I am telling you the reaction I got from it.
The ecm will compensate a little, yes, but not what it fully needs.
You could very well just have dirty injectors, and they need professionally cleaned.
Old Dec 19, 2003 | 11:06 PM
FbodTrek's Avatar
How much would that cost? I don't want the car out of commission for more than a half day. The motor i got is Clean as a Pin, the injectors are new, and I fig'd Id just swap the originals for the time factor.... If it runs rich, I don't mind, if I pay to have them cleaned (I assume I have to send them somewhere ) and it runs lean, I'm pissed. Thanks for the info Though.
Old Dec 20, 2003 | 05:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I wouldn't be doing stuff like that cause of a code. The computer is not always right. Matter of fact the computer is pretty dumb if you ask me. Come drive my car and then pull the codes. it says me computer is bad/fried but it drives like a dream or a raped ape. depending on pedal position.
Old Dec 20, 2003 | 11:53 PM
Dale's Avatar
Engine: 350 S-TPI
Yes, they would have to be sent out to be cleaned PROPERLY. Cost is like 11 an injector
Now, the difference between 3.1 and 3.4 injectors is 2lbs worth, made mine run rich.
The difference between 2.8 and 3.1 is only 1lb. It will prob still run slightly rich, but not as much as mine. If you can get some injectors for cheap, give them a try. I understand your frustration of coughing up a chunk of change, and it still not perform as you want it to. Getting some used 3.1 injectors is prob less expensive then cleaning what you have. May do the trick, may over-do the trick.
You could possible just install a holly adjustable regulator on your current ones. Or get used 3.1 injectors, plus regulator, and tune the pressure down.
Old Dec 22, 2003 | 12:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
He's right, FBodTrek, I haven't. And I -can't- run rich, they throw us on the dyno for emissions in NJ. So now that I know they run rich, I gotta dig up a lowmileage set of 2.8 injectors from Somewhere!! Either that or buy new at $60/pop...
I would've thought the injectors would've varied the pulse length and kept the car from running rich; but maybe that's out of spec for what the computer can compensate for? Eventually (laughs) when I rebuild my 2.8 (I've been saying <i>that</i> for years), I'd be doing some headwork, so the 3.1 injectors might help me then. But now, I can't see dropping that much for new 2.8 injectors. I should do a lookup at gmpartsdirect.com to see how much $$ they want for a set.
Old Dec 22, 2003 | 07:49 PM
FbodTrek's Avatar
Here's what I di for ya....
Well Tom, this is what I found out from my friendly neighborhood parts dealer: "Depending on the type of injectors YOU have in your motor (86?) They could be the SAME as the 3.1 injectors. Turns out the 86 powerplant came with TWO different types of injectors!" The 3.1 only got one type, SO- What you do is, Pull out an injector, call whatever parts dealer you use, read him the part number, and tell him to tell YOU what the part # was for the 3.1 series motors. (I used Hi-lo) If you have the same number as the 3100 series YAYYYYY! All you gotta do is check. (Also, I talked to my inspection guy, he doesn't think it running a tad on the rich side will kill us on our 2.8's, but i suppose I'll just do it and find out) Good Luck!
Old Dec 22, 2003 | 07:54 PM
Dale's Avatar
Engine: 350 S-TPI
They ran two different part #'s? Wack
Give it a try and let me know your outcome.
Like I said, 2.8-3.1 is 1lb
I did 3.1-3.4, and thats 2lbs.
Old Dec 22, 2003 | 10:08 PM
FbodTrek's Avatar
I already did
There are two diff injectors for the 86. Two different part numbers, one of them is the same as the 3.1. I went around and around with the manager of HiLo(good friend of mind) We broke out ALL kinds of parts catalogs, checked the computer many times. Believe me, I was more surprised to hear that than you can believe....Now, Ijust gotta get around to seeing which ones I have.
Old Dec 22, 2003 | 10:20 PM
Dale's Avatar
Engine: 350 S-TPI
Yea, that is surprising.
Ask around and see if their is two different ECM prom codes for a 86 2.8. May be easy/simple as swap in 3.1 injectors, and change bin on ecm (change prom chip for you) and done.
You also said you dont mind if it runs tad rich, throw some 3.1's in it and give it a try. I would advise (but dont have to) reset the ecm if you stick 3.1's in it.
Old Dec 22, 2003 | 10:28 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: ...
You should care about the care running rich because it'll fry your O2 sensor and the cat WAY before they are designed to die.
If you are showing 14.7:1 a/f ratio, then you are running dead on and NOT lean. You have nothing to worry about. If you are getting code 44, then you have a problem somewhere else, it's not in the fuel system if you are showing 14.7:1. This is assuming that you have used some sort of diagnostic tool like an exhaust sniffer of some sort.
Old Dec 24, 2003 | 05:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: I already did
Fantastic! Thanks for the info, FbodTrek!!
Old Dec 26, 2003 | 06:05 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I have 3.1's in my 2.8. They came in the 85 2.8 that I swapped into my car. As far as I can tell, the car runs rich, but not rich enough to cause a problem when driving. However, I am fairly sure I will FAIL the Wisconsin smog test.
Tom, you could BORROW my old 2.8 injectors if you have Rich clean them and have them back to me by JUNE
Old Dec 28, 2003 | 12:54 AM
FbodTrek's Avatar
You're welcome tom...
Since 14.7:1 is "optimal" for fuel economy and emissions, I wonder what is "optimal" for power? I imagine it would vary from engine to engine, but it would be nice if there was some test data out there to show calibrated power curves over different Air fuel curves. Heck, run a really hot spark with a richer condition (it could happen...). Honestly I don't care about emissions or fuel economy (Otherwise I'd drive a 4 cyl...). For all we know, there's power to be had running rich (with the exception of blowers/turbos of course). Anyhow, just a thought....
Old Dec 28, 2003 | 02:59 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
When you go WOT, you want around 12:1 a/f ratio...
Old Dec 29, 2003 | 07:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the offer, Damien! I'll let you know if I've gotta take you up on that!
Old Dec 29, 2003 | 08:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The price isn't to bad for this little beauty to be very useful.
http://www.tazzo.com/tazzo/efi.HTM
Tazzo Electronic Fuel injector Monitor
Measures Fuel Injector duty cycle in real time (0 to 100%).
Individual warning lights for 85% and 95% levels.
Measures the oxygen sensor voltage output.
High speed display.
Filter electronics to stabilize the signal at WOT.
Old Dec 30, 2003 | 01:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Awesome find! I couldn't find any spec sheet on the site though (as in, how it connects)... did I miss a link, or are they just not telling us?
Did a search, found one review on a DSM website: http://www.dsmreviews.com/dsmreviews...azzoEFIMonitor Seems like we get four wires, but only one is for the injectors. So I guess we'd just be measuring one bank of injectors? Or does this get tied into one SINGLE injector? Hm...
Hotrodboba400
Dec 10, 2019 07:07 PM
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
92camaro350cci
Oct 14, 2015 09:29 AM
