any 3.4 swappers
Old Dec 31, 2003 | 04:15 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
any 3.4 swappers
there is a sensor on the pass side of the block. im not sure what it is, but its in the way of the 2.8 motor mount. what is it and when i take it out do i have to plug the hole? it doesnt look like it would leak any fluids, but ive been wrong.
Old Dec 31, 2003 | 05:01 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
It's a ka-nock sensor. Just unscrew & remove, you wont need it. MIght want to save it for later swaps , or sell it & make a little $$ for your swap.
edit: and no, no fluid or anything will leak out, or at least shouldn't It's sealed in the back.
Old Jan 1, 2004 | 06:40 AM
KED85's Avatar
Yeah, it's a dead end plug.
Not problemo!
Just remove & eventually enjoy your new found drivetrain power upgrade!
I do!
Old Jan 1, 2004 | 12:21 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I belive their is a 2nd crank sensor on that side. Don't know if you can just remove it or not.
Old Jan 1, 2004 | 12:55 PM
Engine: 5.7 / 7.4
The cam sensor is up top, just in front of the driver's side bae manifold.
The crank sensor is behind the balancer. I just cit the wires & left the sensors there as plugs.
Old Jan 1, 2004 | 06:21 PM
Dale's Avatar
Engine: 350 S-TPI
I know the cam is up top.
My 94 had TWO crank sensors. One on the timing chain cover, and then another one on the pass side of the block just above the oil pan.
Old Jan 1, 2004 | 07:37 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yeah, the 2.8/3.1/3.4 cars that had DIS all had 2 separate crank sensors. The 18X signal and the 3X signal. Most other cars have the 2 sensors integrated into 1 sensor.
Old Jan 1, 2004 | 08:19 PM
Engine: 5.7 / 7.4
yup, just looked & there it was
Old Jan 1, 2004 | 08:39 PM
KED85's Avatar
HEY CALI!
HAPPY NEW YEAR!
Old Jan 1, 2004 | 09:20 PM
Dale's Avatar
Engine: 350 S-TPI
I just read it was in the way of the 2.8 motor mount
so yes its the knock, however, on my s10 2.8, I removed the knock sensor, and anti-freeze came out, so better safe then sorry, plug it!
Old Jan 2, 2004 | 10:10 AM
drdave88's Avatar
Engine: 6.0L
thanks guys. im droppin her back in the car tonight. i dont have my roller rockers or pushrods yet so it wont be running till hopefully next week.
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
87CamaroLT
Apr 23, 2001 09:32 PM
