chevy 2.8 v6
Old Jan 6, 2004 | 12:38 PM
MurCurY's Avatar
Car: 86 Camaro Berlinetta
chevy 2.8 v6
I have a 87 Monte Carlo with a 2.8 V6. I know...it's not a camaro...but i figured you guys can help me with this. I would like to give the motor a little more Umph...what can I do to it to do that? I do NOT want to drop another motor into it...I just want to modify/upgrade what is already there. Thanks.
Old Jan 6, 2004 | 01:16 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Open up the exhaust, get some headers, 1.6 roller rockers, but before any of that -
TomP's Major TuneUP!
Old Jan 6, 2004 | 01:35 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i second that one!!!!
Old Jan 6, 2004 | 06:01 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
your actually worse off than the rest of us cause your car is much heavier.
I know you said you ddid not want to do an engine swap, but that really is your only option. for what you "Could" gain in modest mods, would only yeild 10-15 Hp which in your true pig would do no good.
Old Jan 6, 2004 | 06:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: chevy 2.8 v6
No offense, but are you <i>sure</i>?? There wasn't any 2.8 for the Monte Carlo's, only a 4.3 liter V6. Monte's got the 200-4R transmission too, which won't bolt up to a 2.8.
Either you're mistaken, or somebody seriously downgraded that car!
I would say to check out http://www.g-body.org ... but I could've SWORN that website looked much different (and had much more information on it) a few years ago. So instead I'll say to check out http://www.darklair.com/monte/ ...
Old Jan 6, 2004 | 11:11 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Actually.......
The monte carlos option was either 3.8 gm (229c.i.) 3.8 buick (231 c.i.) 5.0 gm, or the 5.0 HO (in the SS). It might have been a 350 in the SS that year, I'll check it out, but I'm As positive as Tom, there was NO 2.8 option on the montecarlo....EVER. Check your VIN code and post it, if it's a V6 car, its either 3.8GM or 3.8Buick. (and for the transmission, I know for a fact that they got Turbo 350's until 85,....not sure after that though...)
Old Jan 6, 2004 | 11:48 PM
Jeffs RS's Avatar
Car: 1988 Camaro RS
Engine: 2.8L MPFI
Transmission: 5-Speed
Me thinks that new people should be notified of the search button in their notice that their account is active.
Old Jan 7, 2004 | 03:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Fbodtrek, if he's got an '87, shouldn't it be the 4.3 instead of the 3.8? I knew a kid with an '86 Monte LS, and did research on it a while ago (when I still talked with him); I think that was the start of the 4.3 instead of the 3.8.
Not that it matters anyway... unless it really IS a 2.8 under there! Did you find out yet, MurCurY?
Old Jan 7, 2004 | 03:55 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Pops old 87 SS had a 305HO, and some pos tranny that blew a few times. I'm sure I didnt help it a bit either
I never knew they had a 3.8. I thought they had a 4.3
Old Jan 7, 2004 | 07:34 PM
FbodTrek's Avatar
I could be wrong
Heck Tom, these days I have a hard time distinguishing 5.0's from 350's! LOL. The difference in the 3.8 vs 4.3 is the same difference in the 305vs350. 4.3 is a 350 minus two cylinders, a 3.8 is a 305 minus two cylinders. I'm burnt out man.....
Old Jan 7, 2004 | 08:40 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Re: I could be wrong
Umm, no the 3.8 in the G-body is a Buick engine, not a Chevy engine.
Funny thing with the distributer at the front of the engine.
Old Jan 7, 2004 | 09:36 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
nope
chevy had a 3.8 also
like was stated above, its part of the 4.3 family
Old Jan 8, 2004 | 10:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, I've got a few friends with the 4.3.
But I still don't think there was a 3.8 in the 85-up monte's- I originally thought 86-up, but that's contrary to the information found here: http://dustins76montecarlo.8m.net/photo6.html
Old Jan 8, 2004 | 11:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A 4.3 is a chevy 350 missing two cylinders.
A 3.8 is a buick 350 missing two clyinders.
Only reason I know that is they often swap parts , like timing chaine cover around on the buick 3.8 / 350 for some reason.
GM does funny things.
4.3 is cool but it doesn't hold the glory that a 3.8 does on the street.
Could be its roots. Buick
Old Jan 9, 2004 | 02:43 PM
MurCurY's Avatar
it is a 4.3....i was misinformed. so...what can be done if anything?
Old Jan 9, 2004 | 02:54 PM
Dale's Avatar
Engine: 350 S-TPI
4.3 can have alot of potentail.
However, it is a totally different character then our 2.8-3.4's.
I suggest finding a monte site, or go to s-series.org, and hit up the 4.3 department.
Old Jan 9, 2004 | 03:56 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Re: I could be wrong
how do you figure a 3.8 is a buick missing two cylinders? i have not done any research on this but the math isn't there unless i missed something. three quarters of 350 is 262.5. 262.5 / 61 (CI per liter) is right at 4.3...not 3.8. did buick use another number of CI per liter on there stuff?
Old Jan 9, 2004 | 05:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"The Buick 350 is a factory stroker with a 3.85" stroke...that's more than most other small blocks will ever see.
The BORE of the Buick 350" is the one thing that could be larger. Of course, if you look at what the GN/TR guys are able to accomplish with that same 3.80" bore in the V6 - all hope isn't lost!!! "
Course they did do a few things different. Some guys run the 3.8 timing cover for its oil drive. Same way with the 4.3 its basically a chevy 350 some parts will swap.
I wonder who did it first though. Seams as GM does do allot of copy cat stuff but who said let just remove cylinders from the V8's?
Which was easier then designing new motors and you are starting with a power plant that works.
"2004 race season will be shaken up when the Buick 350 finally gets an aluminum intake and heads. Go TA Performance."
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
