Will fourth gen rims fit okay without spacers?
Old Jan 21, 2004 | 07:15 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Do they fit alright without any problems without the spacers? I need some new rims and can't really find the ones im lookin for but i've seen some nice fourth gen rims going pretty cheap but i don't want to spend 300 for some spacers =/. Thanks.
Old Jan 21, 2004 | 07:18 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
No
Old Jan 21, 2004 | 07:21 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
2" rear 1.25 front.
Old Jan 21, 2004 | 08:04 PM
pasky's Avatar
How about Corvette Z06 Wheels?
Old Jan 21, 2004 | 08:25 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
no, you need a 4th gen rear or spacers 2"front and 1.8" for the rear,you can play with different rear sizes to place the wheels where you want them..
Old Jan 21, 2004 | 08:29 PM
pasky's Avatar
Probably already know the answer to this but can I take the spacers off a fourth gen car and slap them on mine? THanks again.
Old Jan 21, 2004 | 08:39 PM
V6sucker's Avatar
Engine: blown up
no spacers on 4th gens. the hub track is wider.
Old Jan 21, 2004 | 08:47 PM
pasky's Avatar
Well poo, really making this harder for me . Damn adaptors run just about as much as the rims :P.
Old Jan 21, 2004 | 09:29 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
get on ebay, type in AFS Wheels, you'll find a maze of corvette, Gran Sport, Trans Am, and CAmaro wheels, not to mention many many mustang wheels (cobra normally) as well, you should be able to pickup a full set of 4 for around 400-600 bux depending on size, color, and bidding....the same wheels with tires may run ya 800-1000 but it's cheaper than a dealer, where'd you'd expect to pay more than 1000 for the wheels alone. Heck TQ Thrust II's are close to 250 a wheel i believe, and that's for maybe 16's?
Old Jan 21, 2004 | 10:17 PM
pasky's Avatar
Yea, just did and thanks for the advice, however just about everyone are fourth gen, and I wouldn't mind getting them and the adaptors, its just I have to calculate tires too =/.
Old Jan 21, 2004 | 11:17 PM
Ovrclck350's Avatar
WELL
Right now you can get ROH ZS's in thirdgen spacing sized 17X8.5 for around 160-175 a piece depending upon where you go. They're discontinued, so forget ordering them....you'll have to find someone with stock.
Old Jan 22, 2004 | 12:07 AM
pasky's Avatar
What about these:
http://cgi.ebay.com/ebaymotors/ws/eB...category=43957
Im really not even sure what offset to get when buying rims, can someone point me in the right direction? Thanks.
Old Jan 22, 2004 | 01:50 AM
pasky's Avatar
Think I found some that would fit, are in my price range, and look stunning. ROH snypers. Believer they are direct fit for 82-92 f-bodies right? Thanks for all the help.
Old Jan 22, 2004 | 02:31 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
WHy not some uni $20 for 2 autozone spacers that people use to make 6in tires stick out like 12in tires???
Old Jan 22, 2004 | 03:05 AM
pasky's Avatar
Have no idea what those are or if they will work...
Old Jan 22, 2004 | 04:00 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You know. You've seen them imports, or jimmy trucks with 6 in wide tires, but with backing plates that make them stick out 20ft on each side? Just a simple cheap spacer plate n longer studs.
Don't you have to go out 3-4 inches or change the bolt pattern before you need a price billet spacer???
Old Jan 22, 2004 | 09:13 AM
V6sucker's Avatar
Engine: blown up
No, if you go out 1.5+" guess where that leaves your studs at? at the end of that spacer. Now try to bolt the rim which will ad another 2.5" to a stud that is not there.
Pasky, go on ebay and get some 6RD" billet aluminum hell 6L" will do it. You then call machine shops in your area, and ask them how much to cut them to length (cheap) then put a 5X4.75 ON CENTER patern drilled. You will have to be VERY SPECIFIC, on what you want from them. Take them some wheel studs so they can get the Diameter holes needed to pass the threads through, counter them 1" in. on both ends.
I am not going to speak for shops in your area, but one local to me charged me a grand total of $50, and that was using HIS aluminum.
Old Jan 22, 2004 | 11:08 AM
Ovrclck350's Avatar
OK, maybe some of you haven't seen the spacers everyone's talking about. The're really not spacers as much as they are adapters. These aren't something you slide on, they bolt on!!!!. Then they have their own lug nut posts on top. It's not something you can pic up at autozone.
Yes Snypers will fit, but call someone who knows what you need as far as backspacing. THey'll send you the right ones.
Old Jan 22, 2004 | 08:58 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
They're like these. You want some good ones so you don't mess stuff up.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2455971362
Old Jan 22, 2004 | 11:04 PM
Ovrclck350's Avatar
Hmm, I talked to the guy I'm ordering rims from today, and Eibach actually just came out with a different setup.
THey give you different lug bolts that you put in and they're longer (kinda like the studs you have to use in IHRA to run slicks) and then you actually slide a spacer (still 2' thick) onto them, then bolt the rim on.
Oh, and he has lotsa ROH ZS's 17X8.5's left in thirdgen spacing for $160/piece
Old Jan 23, 2004 | 12:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thats excatly what I was talking about and got so much flack for?
Ive seen them kits befoe near the lug nuts. Longer studs and a spacers 1 or 2 for $20.
I believe you only need fancy adapters if your gonna go 4in+ or change bolt pattern.
I believe 2in and under
longer lugs and a cheap uni spacer is plenty. The lugs can handle it fine.
Old Jan 23, 2004 | 01:19 AM
pasky's Avatar
Hey, thats awesome, does autozone or whatever carry the correct size then? If so, what a cheap alternative . I can get some Z06 rims then. Thanks for the info guys.
Old Jan 23, 2004 | 02:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Last time I touched a pair of them was at a western auto that is now parts america. It was in the tires section at one with a big service center.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kah992
Aug 19, 2015 02:55 PM
