True Dual question
Old Feb 13, 2004 | 06:10 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
True Dual question
does anyone know what year 3rd gen came with "true duals"? I know that one of them did, but I can't remember which one, it was one of the V8's and it was only a single model. Also, where was the O2 sensor? Was it in the H-pipe? Just curious if anyone knows.
Old Feb 13, 2004 | 06:31 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Nevermind the year that it was available. I found that it was an option on 89's with the G92 option. It's RPO was N10. Now the question of finding out where the O2 sensor is...
The option was true duals with 2 cats, so there has to be an O2 sensor somewhere. If you know, please hook me up with the info.
Old Feb 13, 2004 | 06:32 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
third gens never came with true duals. late model tuned port performance package cars had dual cats but single exhaust after. 1982 cars had single exhaust but split to dual mufflers
Old Feb 13, 2004 | 06:33 PM
o2 was in exhaust manifold.
Old Feb 13, 2004 | 07:27 PM
Akshay's Avatar
The 5.0L stangs came with true dual. The left & right exhaust manifolds had their own pipes, cat., & mufflers.
The 4.6L stangs exhaust setup was similar to Camaros.
Akshay
Old Feb 13, 2004 | 07:56 PM
4.6 mustangs have the same style setup as their 5.0 l mustangs it is not like a camaro at all.
Old Feb 13, 2004 | 08:33 PM
Akshay's Avatar
Does the 4.6L use the H-pipe as well?
Akshay
Old Feb 13, 2004 | 08:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A camaro and a mustang both have 4 wheels and oddly enough in a similar configuration pointing all the same way. Round too.
Old Feb 13, 2004 | 09:36 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
How in the Fu(k could an fbody have true duals.
there is no space for that.
Old Feb 13, 2004 | 09:38 PM
Akshay's Avatar
By saying a 4.6L Mustang exhaust having similar setup as a Camaro's exhaust, I meant both used a Y-pipe. But I guess I was wrong.
I know the 5.0L stang uses an H-pipe. But I didn't know the 4.6L used it too.
Back to 2_point8_boy questions. Depending on smog regulations, you can have the dual cat. setup installed on your car and fabricate a place for the o2 sensor on the Y-pipe. GM claims a 15-25hp gain (iroc/z28 model).
And get this, GM says that a dual exhaust setup for the Trailblazer is good for 30 extra horses.
Akshay
Old Feb 13, 2004 | 09:46 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Akshay
On what?
Old Feb 13, 2004 | 09:48 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
My old car was a 98 mustang gt, it had dual exhaust all the way back with 4 resonators , two cats and two mufflers. NOTHING like a camaro or firebird And btw WHO CARES? this is a 3rd gen camaro and firebird site........
Old Feb 13, 2004 | 09:58 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
thats what i'm saying. thast is just messed up
Old Feb 14, 2004 | 12:21 AM
bes217's Avatar
They called the RPO N10 dual exhaust, but really what it was was dual catalytic converters that went into a single pipe after the cat.
Old Feb 14, 2004 | 10:26 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
I know that it was only dual cats, but since in cali you can do anything you want after the cat, then you can, in theory, have true duals. What I am looking at, is where the O2 sensor was located on the N10 option. From what I have been able to find out, there was a single O2, mounted in the pass. manifold.
What I am actually looking into is an X-Pipe before the cats, with the O2 mounted in the X, then it splits again into the duals. I have heard really good things about this "X" design.
Old Feb 14, 2004 | 10:46 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
wrong
Old Feb 14, 2004 | 10:54 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
ok... the only thing "dual" was the cat converters.
On the 60's EARLY 70's yes... since? forget it from the factory.
There is room to run true duals, believe it or not. You just run oval pipes. Seen it done many times.
is there a gain? not really, unless you are a big V8, and I mean bigger than 383, or running a S/C.
For the V6? forget it. Not enough exhaust flow. Your Trq will fall through the floor pan to next to nothing. A High flow cat alone costs you Trq, but you do gain minimal Hp.
As far as I know, all but the I4, V6 mustangs from the 70's on were all true dual. But the exhaust for the most part was designed by Flowmaster since the mid 80's. They know their shiznit.
Old Feb 15, 2004 | 02:56 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by 88IROC350TPI
wrong
well hw is it done then?
Old Feb 15, 2004 | 07:56 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
see no asnswer, well if you speak of sumptin i expect you to be able to poove it. I mean i'm not going to just take your word for it.
I'm not that stupid
Old Feb 15, 2004 | 09:11 PM
V6sucker's Avatar
Engine: blown up
I'm not that stupid
actually, I have seen as stated above, many 3rd gens with true duals. And how they did it I also told you.. with oval tubing to actually gain room under the car. A 3" oval pipe is only 2 1/4 tall. But it is also 2 3/4 thick.
Old Feb 15, 2004 | 10:12 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
http://home.earthlink.net/~chris255/
Tuh Duh.
Unfortunately, I just noticed that link doesn't work anymore, had about 6 thirdgens with true dual exhaust setup. here is one:
https://www.thirdgen.org/techbb2/att...postid=1611784
Old Feb 15, 2004 | 10:15 PM
br()bert's Avatar
Car: 85 firebird
tuh duh!!!! page not found lol, didnt dead bird do a dual set up?
Old Feb 15, 2004 | 10:44 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
here's a pic i found somewhere a while back...this setup is for a 3rd gen, it ran UNDER the rear axle. i have some more pics somewhere, i think they're on my other computer. i know i have found a bunch though.
Old Feb 15, 2004 | 11:02 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
I've got a buddy with an '84 Camaro (Sport Coupe) that did a V8 conversion from his blown V6. He made his own true dual exhaust using two factory-style extension pipes, though I can't remember what he did for the H-pipe. I do know that though the pipes sound good, they hang too close to the ground and scape every time him and I went for a joy ride in it. They're mounted as close to the floorpans as he was willing to go with them. I think it's his H-pipe setup that's making his system too low; the rear portion of it goes over the axle rather than under it.
According to the exhaust catalogues where I work, there was never a factory dual exhaust for a third-gen. When I asked around about why that was, I was told that a single extension (intermediate) pipe was better for torque.
I agree with V6sucker on the comment about full duals w/ a 6-cyl....
Old Feb 15, 2004 | 11:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The duals I have seen were run side by side down the stock location. Lots of cars need to be done like that cause of clearance.My Buick "needs" a new cross member to run duals or run them side by side.
Old Feb 15, 2004 | 11:14 PM
Car: 91 Camaro
i know, this isn't 3rd gen, but i put true duals on my buddy's 01 stang with the 3.8 v6. it picked up torque! stock, it would just barely chirp the tires...we put full length headers on it which had 2.5" collectors but we ran 2.25" piping, through dual flowmasters and into some stock GT tailpipes, it'll spin the tire(s) a whole lot more now!
Old Feb 16, 2004 | 12:39 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
basically, here's what I am looking at. If at some point in the future, I decide to do a motor swap, I might want to have true duals. Since the N10 option was a dual cat setup, and here in California you can do whatever you want after the cat, I was doing research on how I might go about getting it "legal" for California. If it was an option for the car, then you can go on ahead and do it without having to have an E.O. number or a B.A.R. label, but since it was only an option in '89, I would have to "do a swap" of '89 motor and crap, which in theory is exactly the same as the motor and trans. options of the previous year.
I know that it would probably be a little pointless on my 2.8, but if I start planning the future now, then by the time it actually happens, I will have some up with an answer for 99% of my roadblocks.
Old Feb 16, 2004 | 04:04 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
i'd still like to see it. seeing is believing
Old Feb 16, 2004 | 04:11 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
well we know they can do it on mustangs
Old Feb 16, 2004 | 06:08 PM
Car: 91 Camaro
being able to do it wasn't my point... it GAINED TORQUE. being able to do it wasn't the hard part.
Old Feb 16, 2004 | 09:06 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
and your point is...
Old Feb 16, 2004 | 09:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
sticky on the exhaust bored...
https://www.thirdgen.org/techbb2/sho...hreadid=204351
Old Feb 16, 2004 | 10:09 PM
Car: 91 Camaro
everyone says that you will lose torque, especially on a v6...a nicely tuned exhasut system will not hurt performance. my point is that making a general assumption that running duals on a v6 will cause you take lose torque, won't always be true. i was simply giving an example to show that running true duals on a v6 engine, stock one at that, can help it if the correct size pipe is used.
thanks for posting the link to that thread, mw66nova! i have seen that one before and it shows some nice dual exhaust setups on 3rd gens.
Old Feb 16, 2004 | 10:38 PM
mw66nova's Avatar
Engine: 7.0L
one thing you have to remember is that the 60* v6 has alot of other limiting factors that exhaust alone won't help. the heads need tons of help and a bigger cam wouldn't hurt. the big bends in the intake manifold design don't help the deal either. it's pretty hard to get these thing to perform well with just bolt on parts.
Old Feb 16, 2004 | 10:43 PM
Car: 91 Camaro
oh yea, i definately agree with that! i know i've got lots more inside my motor.
Old Feb 16, 2004 | 10:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have read many times that until you get above 500hp you do not "need" dual exhaust. A proper single that lets the engine breath is enough but the problem comes when most stock single exhaust do not flow well and then dual seam to make it run better. When a proper single would of done the same thing.
But of course dual are just nice to have, just to have them.
I will do dual on my Buick this summer but wont be doing it to my 6.
Old Feb 16, 2004 | 11:16 PM
Car: '89 IROC-Z
Tuh Duh.
Heres the new link to the 3rd Gen Dual Exhaust page http://mysite.verizon.net/vze84hud/duals
TONS of pictures of duals on third gens
Old Feb 16, 2004 | 11:33 PM
Car: 91 Camaro
thank you! i could not find that page either. i know i had saved it at some point...must have been on my other computer.
anything that has been thought of for running duals on one of these cars is probably on this site! (something close anyways)
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
