3.4........ Hot S#*t
Old Feb 15, 2004 | 08:12 PM
WRENCHMAN's Avatar
Car: 86 fb
Engine: 2800
just out of curiousity..... what Stall converter would u guys run, if u wanted to pump up a 3.4... again, just for fun........ please feel free to leave part numbers ect..... THANKS GUYS!!!!
Old Feb 15, 2004 | 08:17 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
the stock one.
Old Feb 15, 2004 | 10:26 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Under what circumstances?
Naturally aspirated? Nitrous? Blower?
Old Feb 15, 2004 | 10:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
NA, i'm running a 2200. i'd kinda like a bigger one but remember, i'm not runnin a stock v6 either.
Old Feb 17, 2004 | 07:44 AM
WRENCHMAN's Avatar
Car: 86 fb
Engine: 2800
lets say NOS, and a few basic mod's, exahust, intake, bigger rockerarms, new rings, new TC...
Old Feb 17, 2004 | 08:09 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
is a Stall converter same as a torque converter? If so, whats stock rating, and where can someone get one for a decent price. I've been looking around and finding they are 200+.
Wouldnt mind putting a ever so slightly bigger behind my 3.4 when I swap also.
Old Feb 17, 2004 | 11:39 AM
Car: 91 Camaro
yea, stall convertor just means high stall torque convertor. stock is around 1500. on a rather mild motor, i wouldn't go much bigger than 2000 probably. i got mine off of ebay...i can go look up the contact info for the company i got mine from if you all want. its nice, mines a 2200 but it doesn't just free wheel at lower rpms...under light acceleration, it'll still grab pretty good. or, you don't have to rev the motor to/past 2200 to get the car moving.
Old Feb 17, 2004 | 12:21 PM
Dale's Avatar
Engine: 350 S-TPI
um, ok. I'm confused. So you have two different kinds?
Freespin below a certain RPM?
Slright grab below certain RPM?
maybe I just need to stick with whatever the rebuild shop gave me. I just like how my car just wants to go-go-go while sitting at a light. Was told I might need higher torque converter.
Old Feb 20, 2004 | 09:58 PM
LT1guy's Avatar
Car: 1987 Trans Am
We had one built by a local racing transmission/convertor builder in Snellville, GA...Neal Racing. Its the same diameter as the stock convertor, but has a stall of about 2700. It works great with her (Redraif's) cam, though it would be too much for a stocker.
Note: A V8 style torque convertor won't work, you'll have to order one built on a V6 core, The V8 convertor won't even fit in the bellhousing, even though the spline counts are the same.
Old Feb 20, 2004 | 10:14 PM
Dale's Avatar
Engine: 350 S-TPI
how much did the custom one cost?
Good point on the v6 vs v8. Didnt think of that, and I bet most of the ones I see are v8's
Old Feb 20, 2004 | 10:20 PM
LT1guy's Avatar
Car: 1987 Trans Am
I think it was like $175 or so??? I'll ask Shannon and get back to you.
Even TCI told me the V8 one would work...wrong! Not even close.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
