The code 15 fix
Old Feb 20, 2004 | 02:23 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
The code 15 fix
Being that I couldn't pull that stupid plug , I need to find a way to get rid of the code 15. Any ideas? Dale? AM91? Anybody?
Old Feb 20, 2004 | 05:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
By plug, I assume that you are talking about the connector plug. About the only way to get rid of your code 15 is to replace the coolant temp sensor (CTS).
Old Feb 21, 2004 | 02:45 AM
FbodTrek's Avatar
There isn't one....... You misunderstood. I did a 2.8-3.4 conversion. I do not have aplace to install the sensor. How my I allow the sensor to read properly? That's all...
Old Feb 21, 2004 | 09:45 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: The code 15 fix
My bad......................you just weren't very specific on the problem.
Old Feb 21, 2004 | 11:11 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Not near my tech data, what is the Code 15? Only codes I got from swap were for running rich (tps & maf issues) & extinguish fire please
I didn't remove that plug in the back of the head either.
Old Feb 21, 2004 | 11:24 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's for COOLANT TEMP SENSOR circuit (low temperature indicated)
Old Feb 21, 2004 | 12:08 PM
FbodTrek's Avatar
Trickster is right
Say, project, did you run a direct switch?
Old Feb 21, 2004 | 12:49 PM
Engine: 5.7 / 7.4
tHE SENSOR i'M TALKING ABOUT IS THE BYTCH OF A ONE IN THE REAR PASS HEAD, THIS GOES TO SWITCH THE FAN ON.
i ALSO HAD 3 OTHER TEMP SENSORS, 1 FOR THE ecm (BY THE WATER NECK), 1 FOR THE cst (ALSO BY THE WATER NECK) AND A THIRD IN THE DRIVERS SIDE FRONT HEAD, CADDY CORNER FROM THE PASS SIDE SENSOR. THIS IS FOR THE GAUGE.
i REPLCED THE PASS HEAD SENSOR W/AFTERMARKET FAN SWITCH W/PROBE THAT GOES INBETWEEN THE RADIATOR COOLING FINS.
yeah, cap locks was on & it too long to go back & change
EDIT: on the upside, w/the a/c pressure switch jumpered, the way the fan switch is wired, anytime I "turn" the a/c on, the fan kicks in, should be neat for track cool downs
Old Feb 21, 2004 | 08:56 PM
FbodTrek's Avatar
that's the one..
I don't know why IT is throwing the code 15 though. I thought it was just the fan switch.... I guess I'll scan the car again tommorow and see what it says. Maybe it was the CTS, if so, good. T^hat still doesn't explain why my fan is on constantly.....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
