Fabbed an oil restrictor
Old Apr 5, 2004 | 05:00 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Sweet simple little piece.. alot of people who have used oil restrictors in various turbos have gone with .8mm restrictor orifices... I went with .035"/.9mm just to err on the safe side of things.. simple 1" long brass insert for my oil feed hose. Results in tomorrow, unless it works so well that I take the car cross-country to test it.. ... err.. drat. the tranny's still leaking out the input shaft seal.. can't do that.. oh well, results tomorrow
Old Apr 5, 2004 | 06:10 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Woo! Went from 10 to 15 psi hot idle oil pressure! Yeah! not.. There might be some tightening left in the clamp to reduce flow around the restrictor.. we'll find out *after* the turbo has cooled down.
On the real upside, oil pressure response to engine rpm is dramatically improved.. over 30psi hot at 3000 rpm. was lucky to get 20 previously. On the right track, but it looks like the .9mm restrictor might have been too large after all. .8mm for the next attempt.. got 6 feet of bronze rod to keep milling out these 1" restrictors
Old Apr 5, 2004 | 06:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Those are good for vacuum gauges and Id expect boost gauges as well. Give you a smoother needle. I paid extra to have inserts installed in my two vacuum gauges and then I added my own down the line with some .41 motorcycle pilot jets.
I actually bought them for carb tuning bikes but 1 is still MIA and the other is on the 3rd gen dash.
gaugestore.com is where I got em. $7-$9 with pressed in fittings.
Old Apr 5, 2004 | 08:53 PM
TechSmurf's Avatar
Engine: LS1, Scrap
After some extra testing, I'm throwing in the towel. New turbo and 3.1 short block with high volume oil pump have just been placed onto the to-do list. *sigh*
Old Apr 5, 2004 | 11:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Why??? I think you have plenty of PSI for the turbo bearings. crank up the boost and stomp the gas.
Old Apr 6, 2004 | 03:06 AM
TechSmurf's Avatar
Engine: LS1, Scrap
To hell with the turbo bearings.. the main and rod bearings have my undivided attention at this moment.
Old Apr 6, 2004 | 05:25 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
huh, Ask TomP about low oil presure. His is at 0 PSI at idle an been that was for a few years. Long as I have known him. I wouldn't worry to much.
Old Apr 6, 2004 | 06:00 AM
TechSmurf's Avatar
Engine: LS1, Scrap
yeah.. mechanical gauge is next on the to-do list.. anyway, might as well drive it till it breaks.
Old Apr 6, 2004 | 06:31 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea man. Run that sucker till it drops. And I bet it runs for a lot longer than you think. These engines can take lost of abuse and only need a squirt of oil now n then. crank up the boost and go.
Old Apr 6, 2004 | 06:33 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Course where you check the oil PSI might be different too. I wonder where is the farthest point in the system that you can test. long as you got 20 at the end of the run you had plenty over all.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
