click click....Catch
Old May 20, 2004 | 02:47 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
ok my car is acting funny sometimes it will start right up and other times i have to turn the key a few times and all i get is a click...click...click... Startup. im not sure about this. any Advice?
Old May 20, 2004 | 02:51 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Battery charge low, dead cell, loose battery terminals, damaged cables, loose connection at starter, starter solenoid worn... take your pick.
Old May 20, 2004 | 02:57 PM
7plagues's Avatar
damn i was hopein i would jsut get a one thing answer...
Old May 20, 2004 | 03:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Were talking about 10+ year old GM cars right? No such thing
Edit, check your starter selnoid Does it do it just hot, just cold, or random?
Old May 20, 2004 | 04:07 PM
7plagues's Avatar
well its mostly random... no particular time... i think it has more trouble when it first starts up...like after sitting...and cold i live in arizona so no such thing. also when i turn my key to ignition. my battery gauge says its at 9, im wondering if thats low and it should be at like 13 or so
Old May 20, 2004 | 04:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How old's the battery? If it's nearing the 5 year mark, time to replace it. Does the voltage shoot up to past 13 when the car finally starts? If so, the battery's done.
Buy an Interstate battery or Sears Diehard battery or AC Delco battery. Any other battery is a repackaged one... for instance, Pep Boys "Pro Start" is a repackaged battery made by Exide- and Exide is known for being a cheap battery.
Old May 20, 2004 | 04:50 PM
7plagues's Avatar
exactly its shoots up to 13...and no more ...so i guess i need a new battery. well that kinda sucks...huh o well
Old May 20, 2004 | 07:12 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yeah, the battery in a sitting state should have damn close to 12.0 V, since we operate on a 12v system. Most I've seen have slightly over 12. 9 definitely sounds dead to me.... If you want a test, find a trickle charger/starter, if your buddy has one, etc. Run the cables to the battery and switch it to start (mine is 50 amp), and try to crank it over. If it fires up straight-away, then it's definitely the batt. Places like where I work, Tire Kingdom, also have battery testers. We usually do a battery test for free as part of our "quick check" program...the whole check is free. But you usually have to pay for something first. We don't take kindly to tickets with Rotate, Check Air Pressure, and Quick check with a balance of 0.00.
Old May 20, 2004 | 07:54 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
my car does the same thing and has ever since i've had it, about 2 years. i've changed the starter solenoid, bench tested the starter with no problems, replaced the battery and alt. and it still does it. must be wiring somewhere or ignition switch.
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
