GM topend cleaner
Old Jun 3, 2004 | 01:28 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
GM topend cleaner
I called a few GM dealers today to see if they had any in stock they stated that it is illegal to sell/use in california. So my question is what product can I buy that will work just as well. I know Autozone sells some stuff that you can use in your gas or suck it in through a vac line. But i want somehting that will work good. I will be doing this to my car tommorw before i change the oil.
Old Jun 3, 2004 | 01:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I always had good luck with water followed by one of the generic top end or 'intake' cleaners. But mainly, I used water.
Old Jun 3, 2004 | 01:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
My question is, what ISNT illegal in cali anymore
Old Jun 3, 2004 | 01:56 PM
FAST RS's Avatar
Marijuana lol
Old Jun 3, 2004 | 01:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ok so thye stock it and use it in the shop but wont sell it to you then.
Run down to Checker and pick up a berrymen top end cleaning kit. It almost as good a a GM kit, the chemicals are a tad different. You probably will have to ask the counter person for the kit since usually they keep them behind the counter. If you want to really do a job on the top end also pick up a can of 44k and run it in the berrymen can after you use all of that solution.
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I'll tell you this, when the world ends and its time to stand before *** and account for your sins, California is where the line will start.
Old Jun 3, 2004 | 02:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i just use water.
ive taken the heads off after ive done that and they look brand new.
Old Jun 3, 2004 | 02:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I have no idea about cal, but napa sells several brands that do the same thing. They are easy to spot sort of. they look like regular spray cans of carb cleaner, utill you remove the cap. Most have a threaded lip of sorts.
Old Jun 3, 2004 | 04:43 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Wanna explain the how and why of the water thing? I'm very curious. I might like to try it.
Old Jun 3, 2004 | 09:19 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Re: GM topend cleaner
That's not entirely true. The bigger bottles are now illegal but the small 0.8oz bottles are still sold. I use them all the time. pn 12346535 Like $5 each though. I use about 8 of them to do an injector flush and an engine de-carbon.
Also, I learned from some of the BMW boards that I frequent, a product called Seafoam is supposed to be good for breaking up carbon but I've never seen this product in a store. Maybe you could google "seafoam"
Old Jun 3, 2004 | 09:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
seafoam=napa #1 used product in motorcycle world.
Old Jun 4, 2004 | 12:25 AM
FAST RS's Avatar
Ill probly have my g/f pick me up a can of sea foam tommrow now *** only hopes she gets the right one.
Old Jun 4, 2004 | 06:57 AM
Dale's Avatar
Engine: 350 S-TPI
their are 2-3 types of seafoam. You want her to get the white bottle with red wrighting
Old Jun 4, 2004 | 09:16 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Sure:
https://www.thirdgen.org/techbb2/sho...threadid=25876
https://www.thirdgen.org/techbb2/sho...hreadid=174734
https://www.thirdgen.org/techbb2/sho...hreadid=102500
https://www.thirdgen.org/techbb2/sho...threadid=26260
And if you read through, I think the second one, you'll figure out that you can stop wasting money on seafoam and make your own, if you refer the emulsion.
Old Jun 4, 2004 | 10:29 AM
Thanks for the links, I'll read up on that later!
Old Jun 4, 2004 | 11:23 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Not to change the topic, and not steeling it, but what exactly does GM Top end cleaner do? And how much is it? Thanks guys
Old Jun 4, 2004 | 11:31 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
See the links above.
Old Jun 4, 2004 | 11:36 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
In the bike world seafoam is use in the gas to keep carbs clean. It does an awesome job where other products seam to do nothing but cost money.
Old Jun 4, 2004 | 12:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Gumby, it is used alot, more because people are lazy, but us multi carb boys like to pull the line and run our own 'special sauce'. In one of the threads above, Sea foam's composition is listed. You'll see why we run the stuff direct rather in our precious tanks.
Old Jun 5, 2004 | 04:10 AM
FAST RS's Avatar
SEA FOAM KICKS ***..... I used it in my car today sucked it in through a hose while my G/F kept my car at 20RPM lol when the can was done i looked up and the whole street was one big *** cloud of smoke. what exaxtly was all the smoke from... just carbon build up? i lso put soe MMO in my gas tongiht tommorw im changeing plugs wires o2 sensor alternator tensioner distributor etc.
BTW what is the size of the rubber o ring that goes around the distributor? also how do i get eveything to line up when droping it in with the oil pump drive shaft.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RedLeader289
May 28, 2019 01:47 PM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
Marc Brown
Sep 28, 2015 01:40 PM
