3.1L to 4.3L swap
Old Aug 7, 2004 | 10:19 AM
92PurpleHazeRS's Avatar
Car: 92 Camaro RS
Engine: 3.1L V6
Transmission: 4spd automatic
3.1L to 4.3L swap
OK Guys and Gals...heres the question.I got a great deal in the works on 93 4.3L V-6 w/41,000 miles out of Chevy Blazer w/4-wheel drive.I want to swap out the 3.1L from my 92 RS due to hi-mileage (216,880) ,will this engine fit my Camaro?I am also gonna tell the guy I want the computer and wiring harness included in the sale.He wants to sell the engine because the body is practically falling off the truck.Once again,will this engine fit my Camaro W/O any MAJOR changes??
Thanx
~Bob
Old Aug 7, 2004 | 10:36 AM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
This has been asked many times before and the answer is no.
It will require modifications in the enginebay and your trans won't mate up with it.
Old Aug 7, 2004 | 11:41 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
the correct answer is yes. it will fit but it would require all of the same work as installing a V8. it will not bolt up to your current tranny but you can put the V8 version in the car.
Old Aug 8, 2004 | 10:33 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yes you can. It's a PITA, IMHO... Find a 3.4
Old Aug 8, 2004 | 04:36 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
It would be as much work dropping a 4.3 in as it would a v8 swap. BUT compared to a 3.4 i think the work would be worth it in the end
Old Aug 8, 2004 | 05:30 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
basically, yes you are swapping in a V8. Same degree of parts, uses all the same parts as a V8(90* that is- afterall Caddy DOES have a 60* V8)
This will also set you up in case you wanted to swap in a 3.8, 4.3 or later go full V8. The 3.8 gn/TTA motors are killer in a 3rd gen.
Old Aug 9, 2004 | 01:28 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
here's a Q, where would 305 motor mounts place it in the bay since it's essentially a SBC minus a couple pistons?
Also, the caddy v8 northstar isn't a 60* v8...it's a 90* v8 but uses nearly a 60* bellhousing...i know, i'ts sitting on the stand right now.
Old Aug 9, 2004 | 01:58 PM
V6sucker's Avatar
Engine: blown up
Sorry, that is what I meant.
I would be willing to bet that the V8 mounts would put the 4.3 in the same position as a V8.
If your that worried about it, get the TTA mounts.
Old Aug 9, 2004 | 02:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
a 4.3 is a 350 v8 missing the back two cylinders.
Old Aug 9, 2004 | 05:31 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Good luck finding the frame mounts
Unless you get luck you're gonna have to spend 300-400 on aftermarket poly mounts with the frame pads.
Old Aug 9, 2004 | 09:13 PM
V6sucker's Avatar
Engine: blown up
I never said they would be readily availible, I just said that they would work.
Old Aug 9, 2004 | 09:28 PM
fly89gta's Avatar
Car: 2018 Camaro SS
and are you sure they'd work? A buick and chevy motor are WAY different. I'm sure the mounting is different too.
Old Aug 9, 2004 | 09:31 PM
V6sucker's Avatar
Engine: blown up
I'm pretty sure that the block bolts are in the same spot.
jhawkeye
May 25, 2022 06:33 PM
WIzmo
Aug 30, 2015 02:30 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
92projectcamaro
Aug 6, 2015 01:20 PM
