Is getting to the #1 plug easier?
Old Sep 6, 2004 | 12:45 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
OK...I'm doing the usual tuneup and I get to the infamous number 1 spark plug.I can't get the boot off without breaking it so I leave it on and decide to change out the rest of the plugs.It's kinda irritating to leave that one in.Is there an easier way to do it without taking the alternator bracket and stuff off?
-Ken
Old Sep 6, 2004 | 01:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
just yank the boot and go nuts with a ratchet, i've never had a problem getting to any plugs on my v6
Old Sep 6, 2004 | 01:20 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Hwy is this #1 plug so hard for you guys? Is it because maybe the smog pump is in the way?
Reason I ask is because it the easiest one for me to get to, but I don't have a smog pump on my year.
Old Sep 6, 2004 | 01:23 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i have everything on my car, and i still have no problems
Old Sep 6, 2004 | 01:24 PM
BitchinRS's Avatar
This is why I end up replacing my wires along with my plugs wether they need it or not. If the boot is stuck on the plug just yank on the wire. It will normaly pull out of the boot. Then use needle nose pliars to grab the boot and pull it off. Next the conector will normaly stay behind as well. Once again use the needle nose pliars to get it off.
I have found that if I put some dielectric gresse in the boots before putting the new wires on it will help prevent the boot from sealing permently to the plug. Once you have the plug out look at the white part you will see how a layer of rubber from the boot is left on it. This is what is causing the problem.
Also I found that a pair of slim line plug wire pliars helps as well. They coast about $5, but are well worth it.
Hope this helps!
Old Sep 6, 2004 | 04:36 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
i think getting plugs off in my car is the easiest thing to do, especially number 1, just rip the thing off and get new cables
Old Sep 6, 2004 | 06:45 PM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
They make a spark plug wire boote remover tool to keep this from happening. I think its fairly cheap and you can get it from a parts staore or summitracing.com Also at summit I have seen wires that are guarenteed to never pull the boot off the wire for 5 years or they will replace them for you. I have a set, MSD makes them.
Old Sep 6, 2004 | 08:51 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
persoanly i never buy anything for my car unless it has a lifetime warranty, and with wires they better be atleast 5 years.
don't skimp on your car and it'll treat you good
Old Sep 6, 2004 | 09:47 PM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
i have a 3.1 and i use needle nose pliars to pull the plug off the use an extension on a ratchet and have someone hold a flashlight then when i put the boot back on i get the boot so its sitting in place just barely on the spark plug then use the needle nose pliars to put it on and
Old Sep 6, 2004 | 11:06 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
take a mallet/peice of wood & whak the wire boot where it connects to the plug. This will let you move that out of the way, since the plug's getting replaced anyway, and lets you move in w/a regular socket to the nub of plug that's left.
I have to break the middle driver's side plug like this on my 95 Blazer
Old Sep 7, 2004 | 03:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've never had a problem getting to the #1 plug either; I guess it's because I'm an '86 2.8 that doesn't have a serpentine belt? That's an outstanding tip, by the way, Project '85! I like it!
Old Sep 7, 2004 | 05:21 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i have the serp setup and have never had a problem getting to a single plug in my car
Old Sep 7, 2004 | 08:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Along with others, I don't see why everyone has such trouble with the #1 plug. I usually have probs with the number 5 plug...
Anyways, I just pull the wire off by the boot (and I don't have small hands either... I'm just not afraid to beat on them and bend them a little... ) and then use a 3/8 universal joint (AKA swivel) attached to my plug socket to get the plug out...
BTW, I now have all of the options except for the smog pump, but I have the smog pipe running to the manifold on that side...
Old Sep 7, 2004 | 09:11 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
K-D auto speciality tools has a neat spark plug boot puller for $2.49. You can order on line at www.mytoolstore.com/kd It makes getting the boot off number 1 easy. Once the boot is off, use a socket with an extension and an articulating joint to loosen the plug. Once the plug is loose but still in the head, cut a length of hose, six inches or so, and push it on the terminal end of the plug and finish unscrewing it from the head. The hose acts as a flexible extension, and allows you to remove the plug without dropping it. The same trick with the hose can be used to install a new plug in number 1.
Old Sep 7, 2004 | 09:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
why not just buy a spark plug socket? i got 2 of them in my mastercraft 200 peice kit. its got rubber in it so it locks the plug inside the socket
Old Sep 7, 2004 | 09:45 PM
oldschool's Avatar
Engine: 2.8 LB8 HO
Well, of course you have to use a spark plug socket to loosen the plug, given the length of the of the plug. In most spark plug sockets the rubber insert is just there to keep you from accidentlly breaking the porcelain insulator. Sometimes the plug will stay in the socket, often it will fall out. A piece of fuel line hose pushed on the plug terminal comes in handy removing or threading a plug in a tight place where you can't get your hand in, especially for those who don't have a 200 piece socket set.
Old Sep 7, 2004 | 10:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Hey, now, I didn't have a 200 pc. tool set until TODAY and still had the plug socket...
Old Sep 8, 2004 | 09:57 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You just bought a 200 pc set? Cool! I always wanted one... but by the time I could afford one, I already have all the tools that would come in one.
I actually pull that rubber insert out of my spark plug sockets. For me, it's more of a pain in the butt. Like oldschool said, after I loosen the plug, I use an old piece of fuel line if I need to get to the plug. (And that usually only happens on DOHC motors where the plug is too deep inside the valve cover to reach it with fingers.)
I'm curious as hell- Can someone who has trouble with their #1 plug take a picture of the situation and put it up here?
Old Sep 8, 2004 | 02:45 PM
BitchinRS's Avatar
I will see if I can get you a pic tonight when I get home.
It's not really a prob getting to the plug, it's getting a hold of the frigging boot so you don't destroy a perfectly good wire.
Old Sep 8, 2004 | 07:13 PM
bry92firebird's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Transmission: 5 Speed Manual
Here's a pic of the offending sparkplug access if this works.
[IMG]sparkplug.jpg[/IMG]
Old Sep 8, 2004 | 07:57 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
the spark plug boot pliers is a good thing to use. a.k.a. chicken pliers. just grab ahold, and twist the boot, itll pop loose and USUALLY the whole thing will come loose. sometimes the connector will stay behind and you need a new wire.
gta892000
Aug 11, 2019 11:16 AM
Jlanz55
Sep 9, 2015 09:09 AM
J.C. Denton
Sep 8, 2015 05:35 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
89 formula TPI
Sep 7, 2015 11:06 AM
