help me identify these plugs
Old Sep 7, 2004 | 03:30 PM
Mark_Fbird85's Avatar
Car: Trans Am
Engine: 305 V8
Transmission: Auto TH-700R4
Axle/Gears: 2.73 LS
I'am new to the board so I want to say hello to all V6 users
I have '85 firebird, it requires some body work, but that's nothing in comparison for a mess that former owner left in wiring
So I need help in identification of several plugs...
here they are:
best regards
Mark
Old Sep 7, 2004 | 03:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Welcome to the forum! Was the air conditioning pulled from the car?
I'd say that #2 should go to the Coolant Temp Sensor, but I'm not sure; I'd have to look up the wire colors. Can you get the wire colors for #3? It definately belongs to a relay that would be attached to the bracket on the firewall... but not sure which relay (or circuit) it goes to. I think there might be an a/c relay up there... not sure tho.
And #1 "on the firewall" almost looks like the power for the high speed blower motor, for the climate controls... but again, I'm not sure.
Old Sep 7, 2004 | 05:50 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I think #1 looks like a test lead.
TomP they made a high speed blowermotor? My blower sux and its brand new.
Old Sep 8, 2004 | 04:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sorry 'bout that; I should've said the high speed for the blower motor. The first three positions of the heater fan switch go thru the speed resistors in the heater/evaporator box on the firewall. (For those that don't know, look for the thin/wide gray connector with 4 wires coming from it, that goes down into the firewall box. Undo those two 9/32" bolts and you can pull the resistors straight up and out- be careful, they get hot.) The 4th position - the high speed position - goes thru a relay, and the relay gets its power from a fuseable link that connects to the starter motor.
I kinda have the same scenario tho; my original blower motor took a crap (oddly, about a year after I painted it a nice gloss black), so I bought a new one by 4 Seasons. After I hooked i t up, I thought it was busted, b/c it was definately slower than my original. Then again, I always heard 4 seasons' stuff sucked, but I didn't really have a choice (it was winter).
Old Sep 8, 2004 | 05:01 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
mmmm winter with no heat, 2 winters ago my heat went, was great driving around blasting a/c to keep the windows from fogging.
Old Oct 31, 2004 | 08:50 AM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
1...no clue, I have a similar one, and the only thing I can tell you is that the RPMs are not showing up in the gauges cluster.
2...It could not be so hard to see where that plug goes to, move it around and look for a connector that matches with that plug.
3...It looks like a relay connector, I could see the wires but I am sure it should go to some relay like the MAF sensor one.
Old Oct 31, 2004 | 12:58 PM
Car: Trans Am
Engine: 305 V8
Axle/Gears: 2.73 LS
Hello!
sorry for no replys from me - Have some work
And thanks for your replys - that helps me a lot.
TomP - I think that air condition was in the car but somebody remouved it (It's hard to tell becose I don't have RPO codes)
I checked ECM trouble codes and I get code 15 and 34
I know that 15 is coolant sensor and 34 is MAF signal high..
so like watafo said #3 may be for MAF relay
Here is photo of my realys (something is removed - is that MAF relay?) and when I plug Fan connector Fan starts, dosn't matter if ignition is on or off
Edit : I have dash without tach, speed and fuel only...
sorry for my english...
Old Nov 1, 2004 | 07:13 PM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
Transmission: TH 700R
yeah #3 looks like a MAF power relay
here is a page that will help you... take a look
http://www.angelfire.com/realm/skiboy/index6.html
Old Nov 1, 2004 | 11:47 PM
KED85's Avatar
I had that problem too.
Turned out my ECM was fried.
Replaced ECM and the fan constant on stopped.
Fan now cycles on & off accuratly.
Look at wire casing ends to see if they are stripped back from excessive heat, too.
A wave to ya from Southern California!
Old Nov 2, 2004 | 11:31 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Relays
My Haynes manual says that the relay missing on the far right of your firewall is the air conditioning compressor relay. No doubt removed when someone pulled the a/c.
Old Nov 3, 2004 | 12:51 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
I'm another 85 guy and i'm doubting that that is your MAF relay, as i'd have on also, but don't recall one as of yet. I'll check tomorrow (during the daylight and take a peak to see).
honestly, pic number one kinda reminded me of the EST connection, but eh, i'm not sure....ps, three beers and doing well to say the least , i'll look tomorrow and post back for ya.
gta892000
Aug 11, 2019 11:16 AM
Linson
Sep 21, 2015 01:08 PM
Jlanz55
Sep 9, 2015 09:09 AM
angel2794
Sep 8, 2015 06:22 PM
89 formula TPI
Sep 7, 2015 11:06 AM
