how and what can i make a cold air intake from?
Old Oct 2, 2004 | 10:45 PM
vanko's Avatar
hey ya all! i'm 16 and my dad is getting me a 1990 pontiac firebird 3.1 v6. I have a very limiting budget but i wanna give it some extra power as well as keeping mpg's somewhere around what they are now. first thing i thought of was an cold air intake, eventually i figured that nobody makes it for 3rd gen but than i heard some ppl sayin' that they got "custom" cai. If any1 knows how to do that and any other ways of "cheap" power please help out.
Old Oct 3, 2004 | 01:02 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
some pvc pipes from home depot and a K+N filter worked pretty good for me. about $45 total. Just take some measurements of where you want to put the filter, go the the K+N site, find a filter that matches, get part#, order from summit or whoever. Install.
Old Oct 3, 2004 | 01:06 AM
Engine: 3.4
had trouble attaching this in my first reply
Attached Thumbnails how and what can i make a cold air intake from?-knintake.jpg
Old Oct 3, 2004 | 01:41 AM
vanko's Avatar
is there any way i can do custom cai combining units for other parts? does any1 know that recipe?
Old Oct 3, 2004 | 02:01 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
hey dude, welcome to the boards. you definitly will have to make your own cai, but its not hard at all. here is a good article on how to do it on your own
http://thirdgenmods.firebirdv6.com/coldair.html
i personally wasn't too happy with my pvc concoction (really half assed, not as good as the one in the article), so i went to autozone and picked up an intake tube for a civic. my friend had another bend.. i hooked them up and i was good to go. just be creative and make sure everything is tight and secure. here's a pic of mine...
Old Oct 3, 2004 | 11:07 PM
Engine: 3.4
yeah, mine is kinda just laying there at the moment. I really need to figure out a way to secure it to something.
Old Oct 4, 2004 | 06:15 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
what would you do with the sensor, and anyways couldnt you just remove the air box and relocate the sensor
Old Oct 4, 2004 | 08:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The sensor in the air box? It's just a temp sensor. As long as it hangs near your air filter, you're okay; it doesn't need to be directly in the path of the incoming air. Some guys drill and tap a hole into their intake pipe for it. I just wiretied the sensor near the filter, out of sight.
To that sensor and your computer, a degree or two "difference" in temperature won't make a big deal. What you don't want to do is hang that sensor near something super hot, like the engine, or on top of the radiator, etc. So as long as the sensor is somewher near the filter, you're good to go.
Old Oct 4, 2004 | 08:14 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
oh ok thanks. well i tried removing it the other day, it wont unbolt from the plastic, is there someting im doing wrong when im trying to take it off. Theres no more rain so when i get home im gona remove it...
Old Oct 4, 2004 | 06:42 PM
vanko's Avatar
thx for the replies fellas, after crusin' on the internet i figured that i'll have to do my owm "custom" cai. should i change the whole exaust system for dynomax, or i can just put a flowmaster 80 series muffler? or both? than is it worth of putting a high flow cat converter? is there gonna be any gain of power?
than 160° Thermostat, does it add any power?
i nave a BIG question on camshafts, does it worth the money and do i get any power gain?
underdrive pulley, shift kit - what do those do?
and finally the BIGGEST question is about the differentials, does it worth getting it and how much power would i gain?
now suspension. what stuff can i put in that will cost me cheap and make a difference in handling?
please help what you can, i'd really appreciate it.
Old Oct 4, 2004 | 07:02 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Welcome to the board!
To answer some of your questions, yes, some say a CAI adds seat-of-the-pants power (SOTP) I haven't done one so I can't verify that. I will say that none of the ones I have seen people fabricate truly are a COLD air intake- the factory intake canister on your car at least has a duct on the base of it that draws air in from under the bumper- whereas the open cone filters may draw in MORE air, it's air hot from the engine compartment.
Underdrive pulleys- may add a horse or two, but some say they have had charging system problems at low speed becuase they turn the alternator slower.
Gear swap? May make your acceleration better, but unless you can do the labor yourself, it's $$
Cam? A cam swap alone may help some, but a cam swap in conjunction with a set of the now availible PaceSetter headers and a freeer flowing exhaust will perk it up quite a bit.
Suspension? I have found that KYB makes a good gas shock/strut combo for the money.
Well that's all the time I have right now, more at 11!
Old Oct 4, 2004 | 07:05 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Blah blah blah, I typed a heck of a lot here, and the damn side button of the mouse lost it all -
Cliff's Notes -
1) CAI
2) Headers
3) Catback + hiflow Cat
4) Cam + Heads - CL-MTC-5 @ Autozone, and VS-380 springs from Northern Auto Parts
Total - Maybe 20 rwhp. That's about 15% increase in power.
As far as suspension -
1) Poly Tq arm Mount
2) LCAs
3) Subframes
Old Oct 4, 2004 | 11:52 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
all your answers are here... and unless you're made of money, all the stuff listed above is gonna keep you busy for quite a while
Old Oct 5, 2004 | 12:00 AM
vanko's Avatar
im not planning to get all the mods there are, just tryin to pick ones that will give the perfomance for low
Old Oct 5, 2004 | 10:51 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
So is the in take that came on the 85 camaro considered a cai?
Old Oct 5, 2004 | 01:35 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
The intake that came on the 2.8 is said to be the best for the car, I'm not sure about the one in the 85 though. Vanko welcome to the boards. This is a great great place to get information. You should get used to using the search button a lot because most of the things your gonna need to know have already been asked a few times and it's also a great way to find out what other people have come up with.
Old Oct 5, 2004 | 02:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
And off the main https://www.thirdgen.org page, look on the left and find the "Tech Central" box- click on "Technical Articles". After you click that, a new screen comes up on the right. Roll down that list until you see the section in red "Ram Air Induction", then click on those links. The one of interest to Camaro owners is "How to build a ram air induction system for TPI fuel system" - note, choose TPI, not TBI!
Old Oct 11, 2004 | 03:27 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
welcome to the boards, and read the tech articles.
they are great for noobies, and vets alike
Old Oct 11, 2004 | 09:44 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Well I had a slightly different appraoch for both of mine. On my v6 I simply removed the air box, stuck a cone filter on the end and tied the sensor to the wires that go to the headlights. But on my TA, since it is carbed, I did it with dryer hose. I have a scoop under that forces air up into the engine. Now this wont work for you because you need to have the filter at the end of your intake, but you might benefit from using dryer hose as your connections once you have the filter secure. And the great thing about dryer hose is that it's metalized so it wont catch fire easily or melt.
I dont know if that helps any. :lala:
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
