just got 3.4 in!!!
Old Oct 13, 2004 | 09:51 PM
SCcamaro88's Avatar
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
just got 3.4 in!!!
just got a 3.4 out of a 93 firebird. I had to use the intake off of my old engine and put the distributer cap in. i used the 3.4 injecters though theres not that much mre power than the 2.8 if not cant eben tell. if anybody has any questions ill tell you anything on this swap. Oh...one more thing, i need to know if you can make the engine run like a stock 305 or not, and if so what kind of mods?
Old Oct 13, 2004 | 10:22 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
No change???? Have you checked compression???? What's your timing at??? The difference when I did the swap was night and day by a long shot. Sounds like somthing didn't go quite right, or you got a weak motor. A torque difference of 40 ft lbs is very much "feelable", you should be able to burn the tires down easily....Oh yeah, and it should be at least as fast as a stock 305 now.
Old Oct 13, 2004 | 10:26 PM
ross0310's Avatar
using the old 2.8 manifold you lose some of that extra from the 3.4. i did this install on an s-10 with a 2.8 to a 3.4 and there was no diffrence there either because i had to use the stock intake and it just choked it down.
Old Oct 14, 2004 | 01:47 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
everybody on here has used the stock intake, thats the whole point of the swap to look stock.
shoulda noticed some more kick
Old Oct 14, 2004 | 04:20 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I did seafoam and motor flush on my 3.1 and it feels all kinds of faster, I probably gained 5tq if that and it just feels faster, neverming a 40lb jump.
Old Oct 14, 2004 | 06:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
unless you do some serious mods to the 3.4 intake, you have to use the 2.8/3.1 intake.
oh, and congrats on the swap
Old Oct 14, 2004 | 07:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
check your transmission. If its slipping like mine, your not gonna notice crap.
I did the swap on a s10 5speed, whole moly Talk about a difference
Old Oct 17, 2004 | 01:14 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
what would have to be done to use the 3.4 intake?
Old Oct 17, 2004 | 01:51 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
The back of it hits the distributor.
Old Oct 17, 2004 | 02:51 PM
Engine: 5.7 / 7.4
IIRC, different tb tabs, opposite of 2.8 tb.
Old Oct 17, 2004 | 05:19 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
When i did the 3.4 swap in the blazer TBI I dident notice much power difference. I could smoke the tires after the swap but that was the only increase and it was a new GM perfromance parts 3.4L crate engine to boot.
I'd check the timing all the basic stuff mentioned above.
When I built my brothers 3.4 for his 95/96 camaro we did quite a bit of porting on the intake, cam upgrade power max and installed the pace setter system with a dual outlet muffler. It will spank a stock 305 no problem.
Old Oct 17, 2004 | 05:47 PM
KED85's Avatar
Excellent upgrade, don't ya think?
I love my 3.4 powered vehicles.
I await wrapping up my Blazer swap project, very soon.
Old Oct 18, 2004 | 12:31 AM
F585's Avatar
How long did this take you? I want to get another 3rd gen V6 since they're so easy to work on
Old Oct 18, 2004 | 10:02 AM
KED85's Avatar
Lenght of time for swap?
Oh Please
Some can have this done in several hours/one long day.
Me?
I try to take time & be through, so not to have to dive back under hood to correct smething I missed first time the engine was outta car.
I am going back in to correct oil leaks & slip on new chain/tensioner/balancer snout sleeve.
You know the answer to this question way better than anyone else.
PS Big clues...
Read my swap tech thread, buy all parts ya can ahead of time, rebuild/install new stuff on engine prior to installation. With current engine in car, make sure ALL those sensors/functions operate correct. Less guessing after the engines are swapped.
Through Planning before ya pick up a wrench is very clean work.
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
87CamaroLT
Apr 23, 2001 09:32 PM
