3.8 liter power?
Old Oct 29, 2004 | 11:54 AM
Ann.racer92's Avatar
Car: 92 Camaro Heritage RS
Engine: 5.0
3.8 liter power?
i know its not 3rdgen but does anyone know the stock horsepower and torque of a 95 v6?
a 3800 i should say
Old Oct 29, 2004 | 12:04 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
200hp
Old Oct 29, 2004 | 04:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
and 225 torque
yeah, looking at the engien listed under your avatar, it could be interesting, especially if the 6 has a stick.
Old Oct 30, 2004 | 06:43 AM
KED85's Avatar
From my 1995 Full line sales brochure from Pontiac.
3.8 available in Jan 1995 (3.4 issued prior to...)
200HP at 5200RPM
220 foot pounds Torque at 4000 RPM
Came with AUTO ONLY & AC
No clue about later years & sticks.
Old Oct 30, 2004 | 07:37 AM
Engine: 5.7 / 7.4
same rating 95.5~02.
95.5 were auto only in Cali only. 96 saw the 3.4 replaced everywhere.
Old Oct 30, 2004 | 12:36 PM
KED85's Avatar
I JUST FOUND THAT LINE & IT'S CORRECT
CA/MASS REQUIRED 3.8 AUTO!
BUT DOUBT THAT you'd find a 1995 3.8 Firebird/Camaro w/stick.
Later on good probability.
Old Nov 1, 2004 | 11:34 AM
Engine: 5.0
cant find much on these motors at all. i have another camaro identical; to my heritage ima drop the v6 into.
idea is power to weight ration and also im thinking with the v8 suspension that it will absolutely fly around corners!!
is there a turbo kit or supercharger or any major peices to throw on these motors???
Old Nov 1, 2004 | 04:26 PM
Engine: 5.7 / 7.4
try www.firebirdv6.com , but one of the admins is a **** swede so watch yourself.
It for all yrs 4th gen 3800 and some forums for juice, & forced induction. Even a third gen section for those w/the 3rd gens cars.
Old Nov 1, 2004 | 07:02 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Yupe a centrifugal charger is made for the 3800. Thgey are pricey though, you're better off runnig juice for the price.
Old Nov 1, 2004 | 08:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Tech is a mod over there too??? JK
I know of a carbed turbo 3.8 for sale $500, no turbo and [I think] right side exhaust manifold is gone as it had the turbo hookups.
Old Nov 2, 2004 | 12:00 PM
Engine: 5.0
hehehe. im sooo psyched about this project.... going to run the car with no interior, no dead weight up front, no ac,. it will be light, very light. going to try to find carbon fiber hood for it because ive seen them before. put this biotch on a diet! ohhh my..... id like to put the supercharger on it.. im expection that with computer tuning and a good exhaust i could put out like 220 hp and hopefully 240 tq. i've got the 4l60e to go with it infact i have a full wrecked 4thgen im pulling everything from.
Old Nov 3, 2004 | 01:03 AM
Engine: 5.7 / 7.4
computer programing http://www.hptuners.com/products.html
make sure yo uget a 97pcm, as it will plug & play in place of the 95~96 pcms
Old Nov 3, 2004 | 01:09 AM
Ovrclck350's Avatar
You sure it's the 3800? Not all 95's came with the 3.8. Most had the 3.4.
Old Nov 3, 2004 | 11:09 AM
Engine: 5.7 / 7.4
3.4 4th gen
95~97 3800
Old Nov 29, 2004 | 06:45 PM
Engine: 5.0
positive. the big letters on the intake "3800" were a clue... ;>
i drove it in my back yard, cant get much of a feel since the car isnt even straight but it def had torque.. not bad for 100 bucks.. how much of a pain this is going to be to swap into the car is still making me antzy
Old Nov 29, 2004 | 08:53 PM
Engine: 5.7 / 7.4
since you have the donor car, pretty much drag & drop. new brackets & y-pipe. WIre it up & crank (yes, I've curtailed it a bit )
Old Nov 29, 2004 | 11:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just seen something interesting. Might be worth keeping in mind when look for parts cars.
"The earlier SC3800s such as mid 90's had a problem sucking in the blower to manifold gaskets."
"95 Riv...up to 110K w/ original S charger"
It does take work to use FWD parts but worth it if you find a SC3800 with running problems cheap.
neilb
Oct 4, 2018 12:36 AM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
