MPFI to Carb
Old Nov 14, 2004 | 03:36 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
MPFI to Carb
Can a MPFI 2.8 be switched to a carb setup easily? I already have the complete fuel injected engine and a complete carb'ed engine. Would I just switch the intake and distributor?
Old Nov 14, 2004 | 04:21 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i read somewhere that the heads need to screwed with to make the intake fit, i'm looking into this too.
too many problem with the computer
Old Nov 14, 2004 | 05:06 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Ive been lookin through the Haynes manual and the heads seem to be the same. Kretos you have the exact same Camaro as I do,year, colors, and tranny, but I replaced the 2.8 with a 355
Old Nov 14, 2004 | 06:03 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
no, you shouldn't have to do anything with the heads. 5.8, are you talking about switching the v6 to a factory carb setup? if so, i wouldn't do it, the stock 2 bbl carbs on these motors were not good for power. if you're talking about putting the edlebrock 4 bbl setup on it, go for it, it's not too hard.
Old Nov 14, 2004 | 06:08 PM
Car: 1988 Camaro
Engine: 350 V-Eight
I have been trying to sell my 2.8. A guy wants it, but his is a carb'ed 2.8. He dosent have the MPFI wiring harness and neither do I, so I was thinking mabey he could just use his carb stuff.
Old Nov 14, 2004 | 06:19 PM
Car: 1988 Camaro
Engine: 350 V-Eight
And what about a fuel pump? Are the fuel injected 2.8's drilled for a mechanical pump?
Old Nov 14, 2004 | 06:42 PM
Car: 91 Camaro
i'm not sure if you could put a mechanical pump on it or not but you can run the stock electric one and put a regulator inline.
Old Nov 14, 2004 | 07:08 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Thats what I did with my 355, but the guy that wants this v6 dosent have an intank electric pump. I know he could buy an electric pump to go in the engine compartment, but dont know how much money he wants to put into this.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
