IAC plate ontop of throttle body
Old Nov 27, 2004 | 03:41 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
So I broke the bolts that hold the IAC onto that plate that sits ontop of the throttle body because I'm stupid and mess with things that work fine. I was wondering how much pressure there is on the IAC pushing it out of that plate. I drilled the bolts out best I could, but the aluminum is somewhat thin around the holes in 1 or 2 spots because I could drill straight through the bolt. I'm planning on getting 2 bolts with 2 nuts that are like 9/64's. Will bolts that small be enough to hold it in there?
Old Nov 28, 2004 | 01:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: IAC plate ontop of throttle body
Damn that was the funniest thing I read in a long time; I'm the same way! But otherwise I can't answer the question. Shouldn't be much stress; I doubt the stepper motor really bottoms out hard against the IAC passageway, but I could be wrong.
Old Nov 28, 2004 | 11:41 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
glad to know that I'm not alone in my pointless meddling with things that are fine. Least it's always a learning experiance.
Old Nov 28, 2004 | 12:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
lol, why does this ring a bell?
Old Nov 28, 2004 | 12:27 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
those smaller bolts will be fine. when i first tested my new TB, i had the top plate held on by 2 small bolts with nuts. it sealed up ok with only 2 bolts in it so i'd say having 2 along with the others, you won't have a problem.
Old Nov 28, 2004 | 01:00 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
it's just the actually motor for it, not the whole plate. those 2 bolts that hold the motor on.
I just put it all back together with some mega gray liquid gasket, as much as I hate to use the crap I can't wait for an ordered gasket to come in as I NEED the car tomorrow. I plan on buying a used throttle body in the next few days anyways...
40mins to install upper intake, throttle body, throttle body bypass for the coolant lines, alternator and smog pump...that a record?
Old Nov 28, 2004 | 01:19 PM
Car: 91 Camaro
ohhh...ok. i must have misread your first post. i would guess that would be ok too. you mentioned a gasket...mine only has an o-ring in there, no gaskets. what are you gonna get another TB for?
Old Nov 29, 2004 | 01:11 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I do way too much learning this way! Well for Joe and I its always under the guise of making the car run better! And its always the the easy stupid small stuff that gives us the worst problems!
Old Nov 29, 2004 | 03:40 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Theres an oring on the motor for the IAC. The plate that the IAC motor sits in has a gasket between it and the throttle body. That gasket I need to special order but the liquid gasket seems to holding fine, car ran fine today going to and from work.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
