Problem
Old Nov 27, 2004 | 06:09 PM
90camaropb's Avatar
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
Problem
My car turns over, idles but if i give it gas it drops rpms and if I give it enough it will die. like it getting choked by to much gas or to much air. cousin told me it could be the Oxygen sensor, any others.. Does anyone else have a possibility or had a similiar problem
Old Nov 27, 2004 | 07:42 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Sounds like a vacumn leak ( a big one). If not that, the MA sensor could be wasted.
Old Nov 27, 2004 | 08:14 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Yes, look for a vacuum leak.
Old Nov 28, 2004 | 12:28 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
there is no MAF if its the '90 listed under his username. 3.1s are all MAP based setups.
Old Nov 28, 2004 | 06:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I suppose it could also be a severe out-of-correct-timing problem, too... one that gives a super-weak spark- but definately check for the vacuum leak first.
Let us know what you find!!!
Old Nov 28, 2004 | 07:22 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
could be a plugged cat or possible ignition control module. ive seen both do that
Old Nov 30, 2004 | 11:42 AM
spike13143's Avatar
Car: 1986 Camaro
Engine: 2.8L STOCK
Transmission: stock
Plugged exhaust could cause it to do that. Take off o2 sensor and check for pressure in exhaust. If it's high, then it could be cat or muffler. To check which, you need to punch out exhaust right before the cat convertor.
Or vacuum leak...
Old Dec 2, 2004 | 06:23 PM
90camaropb's Avatar
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
culprit= bad injector
Old Dec 2, 2004 | 09:29 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Musta been one HELL of a bad injector!
Old Dec 2, 2004 | 09:52 PM
drdave88's Avatar
Engine: 6.0L
yeah, i dont think an injector would be quite that bad. a car can run on 5 cylinders, even if its rough. what hes describing probably wouldnt be caused by an injector.
Old Dec 2, 2004 | 10:31 PM
Nixon1's Avatar
That's him updating...apparently it WAS a bad injector.. Which was why I was surprised.
Old Dec 3, 2004 | 06:43 AM
drdave88's Avatar
Engine: 6.0L
damn, i need to pay attention, lol. thats what happens when your manager quits and youre stuck managing a body shop..... w/ very little training, lol.
Old Dec 3, 2004 | 09:44 PM
Nixon1's Avatar
Congrats on your promotion.....or....something...
Old Dec 3, 2004 | 11:23 PM
drdave88's Avatar
Engine: 6.0L
lol thanks. its been a nightmare, but the $$ makes it all worth it
back to topic, so it was a bad injector, hmmm. weve all learned something here.
Old Dec 4, 2004 | 02:56 AM
5SIZ's Avatar
Car: 1987 IROC-Z
it had to be more then that, a car can run on 5 cylinders. me qand my friends always pull each others injecotr clips off just to bust each others *****.
it'll run but smell like fuel and run rough.
Old Dec 4, 2004 | 11:40 AM
Nixon1's Avatar
I agree that its hard to believe the problems were from only a bad injector...but if thats all he replaced, and that fixed it....well....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
