Out of Ideas and need help
Old Jan 11, 2005 | 01:03 PM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
OK here is the deal. I recently replaced my intake manifold gaskets, rocker arm cover gaskets, and fuel injector o-rings on my 2.8 ltr MPFI v6. I've got it reasembled, and its not working right.
Here is what its doing
Starts but the rpm immedetaly drops down to 0 and teh car stalls immedetaly onless I hold down the throttle to about 2000 rpm
Hi pitch squealing sound coming form engine. The sound gets higher and higher when the rpms go up
White smoke coming form the exhaust manifolds
I'm out of ideas, i hope someone can help
Old Jan 11, 2005 | 02:06 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
You've not got the manifold sealed properly, and you have a bad vaccum leak. Also, the smoke sounds like coolant getting burned off. You may have a blown headgasket, improperly selaed intake manifold gasket, or a cracked head to cause that. Take it to a shop and let them look at it.
Old Jan 11, 2005 | 06:07 PM
Karr1986's Avatar
any other suggestions, plus the timing is screwed up on it so it wount stand there and idle, how can it be driven?
Old Jan 11, 2005 | 10:45 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Well, here's the smart-*** answer...by fixing it.
now, something helpful:
If you replaced the lower manifold seal, then I bet you are leaking coolant into the motor as stated above. You'll have to rip it apart and redo it if that's the case.
does the white smoke smell like oil or antifreeze?
Old Jan 11, 2005 | 11:46 PM
Karr1986's Avatar
It doesnt smell like oil, and I've never smelt antifreeze so i don't know.
talking with some friends its a vaccum leak (duh), so I'm tearing into it again tomorrow and re sealing the intake.
wish me luck
Old Jan 12, 2005 | 09:15 PM
Karr1986's Avatar
Problem fixed as of now. one of the intake gaskets slipped and the manifold wasnt torqued down enough. Thanks to everyone who helped
Old Jan 14, 2005 | 07:23 PM
Karr1986's Avatar
she is still screaming. I have my low speed idle, it sounds like a leak in the fuel rail somewhere, Any ideas
Old Jan 18, 2005 | 01:09 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
is the engine running rough? like really rough and when you drive it there is no power?
check to see if your injectors are working.
i had 3 injectors stop and my engine steamed and smoked like crazy
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
