2.8 flooding Problem Help Please
Car: 85 Firebird
Engine: 2.8
Transmission: automatic
Hello, I have a 85 Firebird with 2.8 Multiport, It floods terrible. I have changed the plugs, wires, dist. cap, rotor, fuel injector o rings, coil and fuel pressure regulator. None of this helped, I have checked the fuel pump pressure and it is in range, the car shows no trouble codes. I can unplug the mass air flow sensor and the car runs better with limited flooding but the engine still sounds like it is smothering. Any help you can give me will be greatly appreciated.
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
What ever happened to that flooding problem
So what ever happened to that flooding problem?Did unhooking the Cold Start Injector work? I have the same problem as long as it's plugged in, the car starts fine;don't plug it in and it floods like a siff.
Where I live, it gets cold fast and it is frustrating to have the car not start on the first try because if it doesn't , uh ohh...Damn!!!
Ron
New Brunswick
Canada
Ron
New Brunswick
Canada
Car: 85 Firebird
Engine: 2.8
Tried the cold start injector, it did help some. so I changed it and the Mass Air Flow Sensor and thank goodness it runs great now. Thanks for all your help.
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
What do you mean you replaced the cold start injector, didn't know you could do that? Any info on that would be great. Thanks
And your welcome, glade to help
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
csi , no not the show
, is held on the back by a bolt. It has th efuel liine going to it & the wire harness to it. A bytch to get to on the car, but easier w/the upper manifold off.
, is held on the back by a bolt. It has th efuel liine going to it & the wire harness to it. A bytch to get to on the car, but easier w/the upper manifold off. Thread
