new suspension and brake components installed pics.
Old May 14, 2005 | 03:47 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
well other than a little problem here and there, 2 cars breaking the same day, a wheel bearing FUSED to the wheel stud which can be seen here. i had to cut it off and it scorrd my stud a little. nothing i can do now.
https://www.thirdgen.org/techbb2/sho...hreadid=297697
im overall happy with my stuffs.
so at a total cost of around 400 CAD$ in parts for struts, shocks, springs, swaybar endlinks, brake lines and hoses, calipers, caliper bolts, wheel bearings, and balljoints, plus 320 CAD$ labour to install ... i think thats it..
and i know the crossdrills are going the wrong way, they were uneven a little so i just flipped them sides for a while.
Old May 14, 2005 | 11:37 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Those are not directional vane rotors so it does not matter which wat the rotors turn with the drill pattern. They can be flipfloped without any harm.
You can not run directional vane rotors backwards. Pad debris and other debris will bunch up inside the cooling vanes if they are angled, yours are straight so the debris can escape no matter which direction they turn.
Old May 15, 2005 | 02:38 AM
Car: IROC Z
Engine: 5.7
hey, my water shields are shot. where can i get new ones?
Old May 15, 2005 | 08:40 AM
KED85's Avatar
S-Series truck front shields, two wheel drive, are the same as the F Body.
Nice work.
Cheapest may be to just weld metal over worn out spots on current.
Old May 15, 2005 | 01:48 PM
Car: IROC Z
Engine: 5.7
they disentegrated
serious. i smacked them against the cement and peices of rust flew off them till there wasnt anything left
Old May 15, 2005 | 09:46 PM
KED85's Avatar
Seek out the S-Series vehicles for your object of desire.
Bet it'll be easier score for ya.
Old May 15, 2005 | 10:27 PM
Car: IROC Z
Engine: 5.7
s-series?
s10 s-15
Old May 15, 2005 | 10:52 PM
KED85's Avatar
S-15
S-10
Jimmy
Blazer
TWO WHEEL DRIVE!
Those front end parts, yes they the same
TWO WHEEL DRIVE S Series.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
TheExaminer
Aug 25, 2015 07:34 PM
