What exactly is "hot" for the 3.1?
Old Jun 7, 2005 | 11:24 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Since 220 is in the middle of the gauge,it cant be that bad.But 220 degrees is a pretty freakin hot temp.What is a "hot" temp? How hot untill head gaskets burn?
Old Jun 8, 2005 | 02:09 AM
1320 Right Ln.'s Avatar
you'd have to get close to 290-300 to blow the head gasket, but 220 won't break anything. I do however prefer to stay between 180-200.
Old Jun 8, 2005 | 11:11 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Right around 240-260 is hot. Most cars will boil over in the overflow tank and barf all over right around 240-ush
BTW 1320 Right Ln: Nice Pic of The Cheat
Old Jun 10, 2005 | 03:23 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
Well if mine ever gets to 240 when i shut it off its not starting back up for atleast 10 mins....
Is this common or should I look into this?
PS don't mean to steal ya thread man
Old Jun 10, 2005 | 04:49 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
if mine hits 220, I'm freaking out
normally its below 200.
Old Jun 10, 2005 | 08:57 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
The fans normally turn on at around 220, so that's nothing to worry about.
Yes, if the car won't restart when it's hot, there's a problem.
Old Jun 12, 2005 | 03:53 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
MInes averages about 230, then my stupid fans kick in. But the wierdest thing is when i drive it on the streets, i can hear my radiator reservoir tank bubbles after my fans kick-in (temp does drop down to about 180-200)... IS that normal or is something wrong...
Old Jun 12, 2005 | 10:38 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
something is wrong if you hear the bubbling in the tank. That means that the water pressure is leaking past the radiator cap and boiling in the tank. I would replace the radiator cap just because, then if the problem persists, I would have the entire system pressure checked.
Old Jun 12, 2005 | 10:56 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I thought the pressure cap needed replaced, do I go with 13 lbs or 16 lbs of pressure?
Old Jun 12, 2005 | 07:48 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
right, the cap on the radiator is the pressure cap. I have a 16lb on mine. Never had a problem with boiling in the overflow tank.
Old Jun 12, 2005 | 08:34 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
GM made it so the fans turn on at 230 due to emmissions. Kind of annoying. When I bought my Camaro, I didnt know this so I thought the fans didnt work and I lived in the desert...
Old Jun 12, 2005 | 08:38 PM
KED85's Avatar
Toto, we're not in Kansas anymore
WE'RE IN PALM SPRINGS, THE DESERT!
My fans kick on at 217* an off after it hits 190*.
Recent test results not a "certain gauge".
Honolulu, nice place to overheat........
Old Jun 12, 2005 | 08:45 PM
Car: 88 Camaro
Engine: 310 LG4
I just moved to KS, I hate it, i'm going to Phoenix next year. I miss the desert.
Old Jun 12, 2005 | 08:51 PM
KED85's Avatar
Sorry didn't know the location background story.
Glad ya not offended!
I hear there's an apartment for rent on a corner in Winslow, Arizona....or is that space in the back of the Ford pickup? I hear some girl as the place for rent...
Check cap, check quality of the rad fluid AND check air dams on the car IF they are still there (there are three, two behind grill & one down under car)!
Old Jun 13, 2005 | 12:07 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
It worked for mine... just bought a 16 lb. vented safety radiator cap...
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
