Injector Cleaner
Old Jun 24, 2005 | 05:10 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
Transmission: 5 speed
Injector Cleaner
I was thinkin of puttin some injector cleaner in my gas tank, My injectors arnt bad or nething but i figured it cant hurt to help them a bit....anyone have suggestions on a real good cleaner? i got an 88 2.8 liter
Old Jun 24, 2005 | 05:59 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I have a bottle of stp fuel lnjector cleaner i havent used yet so i dont kno what to tell you about the product
Old Jun 24, 2005 | 06:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
how much is the GM brand cleaner?
also, since seafoam does such a good job cleaning, read up on if it'll do agood job on the injectors.
Old Jun 24, 2005 | 06:24 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I've used Chevron Techron in the 3.1 in my Beretta. I think I put it in there somewhere around 90k (at 116k now) and I'm convinced it helped. I don't have any proof, but I felt it was worth the $7. I have another bottle I'll probably use when I get to 120k.
Of course, if your plugs and wires are crap, injector cleaner isn't gonna do much for you.
-Dave
Old Jun 24, 2005 | 10:29 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
I use STP and techron,good stuff....
Old Jun 26, 2005 | 09:59 AM
KED85's Avatar
In all honesty, the quality of todays gas is so far superior to using cleaners.....the phrase "Clean buring" is not a market campaign, it's mandated by EPA laws.
That said, I've always had great results with Liquid Gumout products.
PS Great choice in Corvette!
I have a 1974, and have had others, too. That's not the original 4-speed in there is it?
Old Jun 26, 2005 | 10:22 AM
Engine: 383, 327
Yep, it's the original 4-speed. It was/is my parent's car that they've owned since '65. They are the 2nd owners. Their car, but I do some of the work on it and drive it pretty much whenever I want.
-Dave
Old Jun 26, 2005 | 01:45 PM
KED85's Avatar
That should be a Muncie M-20.
1966 is first year of the M-21 & M-22 availability.
I enjoyed the shifting on my M-20 in my 1966.
Is your shifter throw shortened?
I did that trick on my 1966.
It was the factory shifter, also.
Relocate the stick shifter arms on the transmission, (if yours has this) to the lower attachment holes. Decreases gear change throws by a good inch or more.
Lucky, family owned since 1965! Good for you!
Old Jun 28, 2005 | 04:37 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Ive used Lucas a couple of times. I here the products are pretty good.
Old Jun 28, 2005 | 06:18 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I've used valvoline synthetic injector cleaner and it did wanders. A salesman told me that the other cleaners contain tolulene and it damages the rubber after awhile. I had a pontiac 6000 that didn't want to start. I used something in a red bottle and it worked wonders. My car actually acted like someone put sugar in it.
Old Jun 28, 2005 | 06:27 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
How can you tell if the injector cleaner uses something that is a good substance? What is the chiemical to look for?
Old Jun 28, 2005 | 06:44 PM
i was told to stay away from petroleum distillates.
Old Jun 28, 2005 | 06:54 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
what are the good chemeicals?
Old Jun 28, 2005 | 07:01 PM
no clue what to look for, I was told to the valvoline synpower was the best, I thikn that's what it's called. It wasn't the most expensive and it wasn't the cheapest so I guess it was good stuff. I would've kinda been weary if he would've pulled out a $20 bottle of injector cleaner
Old Jun 28, 2005 | 09:48 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have used valvoline, stp and some other brands but i like TL3 it is 3.99 a bottle and works great and you do notice a MPG increase after using it. My g/f did not use it for about 5 months put some in and her milage went back up. It comes in a black bottle used to be blue and i think its only sold at autozone.
Old Jun 28, 2005 | 09:55 PM
FAST RS's Avatar
Originally posted by firebird45331
A salesman told me that the other cleaners contain tolulene and it damages the rubber after awhile..
MMO will fix that problem I also use that in my gas tank every 6000 miles.
Old Jun 29, 2005 | 10:38 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
should one use injector cleaner based on mileage?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
edoff13
Sep 11, 2015 03:55 AM
