blown tranny
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
blown tranny
only have first gear to start in then i can shift into drive and the higher gears will work. (auto). question is my friend has a v8 tranny. not sure if its a th-350 or a 700r4 or wat. but can i use my current bell housing and use his tranny, and will it have to be the 700r4? ur help is appreciated.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
cause it's got mAd t0rq, y0!!!11!!!!!111111111!!!
Those other trannies will work.......w/an adapter plate. Otherwise, just get a v6 replacement & do it right & easier.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It easy to blow a tranny with 100s of 1000s of miles with little to no service. My T5 went at 200,400 miles
Just funny as last night I noticed I am getting close to 220,000 miles.
Less then 20,000 miles in 5 years? I need to drive more.
Car: a car being parted out
Engine: blown up
Transmission: in peices
personally I have never trusted auto to last all too long.
That is just me.
As far as using your freinds V8 trans... nope, same type, different bellhousing. But you could pull both apart and swap the guts... but hell then you are rebuilding it, and you might as well spend the 2-300 and get new parts to replace everything...
That is just me.
Find a 60* V6 tranny core from 1988 & later.
It's a stronger upgrade to your current object.
Rebuild that better tranny.
Then swap and not worry no more.
Could/should run ya $600 range of parts & labor.
Car: 1990 Camaro RS
Engine: 3.1L v6
mine is a 1990 already. how feasable is rebuilding a tranny? ive never done one before. anyone know of sumwere i could buy a rebuilt one or used with not too many miles on it?
Engine: blown up
If yours still moves, try to find a parts/core trans and rebuild that, or have that one rebuilt.
Forgive
When I offered suggestion I not noticed your car year.
Ya got the good one already.
Find a reputable shop
Don't try it yourself.
IT'S ALOT OF EFFORT TO FINALLY THINK YA GOT IT RIGHT (trying to rebuild it) THAN TO LET/PAY ANOTHER TO DO IT & get a warranty.
PS That don't mean ya found the best shop tho.
Do your best to get a good word of mouth recomendation.
The cost will still run ya up to $600 range.
DO your best to find best word of mouth reputation shop for the work.
Send a post over to the tranny side of this Third Gen site and maybe a lead could be found that way.
Car: 1990 Camaro RS
Engine: 3.1L v6
sounds good thanks man. i dont think i could handle a tranny yet beyond me i think. anyways for the next week at least i need sumthin so maybe a pik n pull tranny jsut to get me to work/school and back till i can afford to have mine rebuilt? good or bad idea?
The correct solution is to have the car fixed.
It takes less than a day
IF "they" do the labor expect (CA prices) of atleast $1000.
Others can recommend, but you know the correct solution.
Have it done, as soon as ya can afford it.
And find other transportation until yours car is fixed.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
