3.1 V6 engine wight with all parts (alternator, acc etc.) ???
Old Oct 22, 2005 | 03:26 PM
GM-LSX's Avatar
Car: Pontiac Firebird T-Top
Engine: V6 3.1 170HP and LSX swap in mind
Transmission: TH700-stock
Axle/Gears: 3.23 -stock
Hi
I need know this for block-selection on my V8 build up and swap. 195Kg for an complete LS1 seams pretty light. So i was thinking about using an Big-Bore 6L Vortech Block that is 15Kg (about 35Lbs) heavier. Dosen't sound much unless the 35lbs are in the wrong place -> Front
Old Oct 22, 2005 | 08:35 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
what in the hell are you asking?
start there and maybe we can do something...
Old Oct 22, 2005 | 10:44 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
judging by the subject line i think he wants to know the weight of a V6 with all of the accessories...
I don't know it off hand, though.
Old Oct 23, 2005 | 10:43 AM
GM-LSX's Avatar
K.I.S.S. I got it
Weight of the 3.1l V6 (LH0) engine with all of the accessories? All but Trany of course.
Old Oct 23, 2005 | 01:27 PM
V6sucker's Avatar
Engine: blown up
Originally posted by GM-LSX
K.I.S.S. I got it
Considering that a freind and myself were able to lift it into the back of a truck, 3-400 lb's at most.
Old Oct 23, 2005 | 04:54 PM
V6#22's Avatar
They are just shy of 350 lbs with the entire intake setup bolted on in running condition. A V8 can exceed 600lbs with all iron parts, an LS1 is 459 lbs fully assembled with intake and a flexplate for an automatic trans
Plus you have to remeber that the fore to aft center of gravity of the motors weight sits more rearward on a 60*V6 than even an all aluminum LS1 V8 by about 3 inches to the CG of the car. All the V6 motor weight is behind the front wheels.
Old Oct 23, 2005 | 06:43 PM
GM-LSX's Avatar
Thank you for your answer V6 #22 Looks like more money on the block. Less on shipping and gas
Old Oct 24, 2005 | 02:05 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hmm...
Am deutsch 350lbs. could be 159 Kilograms fur das motor V6.
Denis V.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
guy76767
Aug 6, 2015 05:58 PM
KeithM
Oct 1, 2000 09:28 PM
