Roller tiped rocker
Old Dec 2, 2005 | 09:43 PM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
rOLLER TIPED ROCKER
hI aLL
i HAVE THE 3.4L crate engine, with the Holley 4 barrel, Edelbrock intake manafold, headers. the stock 3.4 cam. is going to the 1.6 ratio roller tiped rocker worth it (really worth it) or should I just put the 1.5 ratio roller tips.
Paul
Old Dec 2, 2005 | 09:45 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
don't bother with roller tips, go with full roller.
less friction= less heat= more power
not a ton but worth the cash
Old Dec 3, 2005 | 09:20 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3-5 hp at peak. I took my roller tipped back off.
Also pre-warning. If you go to 1.6, you need to make the pushrods longer to the tip of the rocker hits center on the valve stem.
Old Dec 3, 2005 | 04:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
why do you say that? I'm running 1.6s with stock pushrods and have no issues.
Old Dec 3, 2005 | 10:14 PM
Dale's Avatar
Engine: 350 S-TPI
Dean found this info a while back, and linked me to the source. Dont have it anymore.
When I pulled me 1.6 rockers off a few weeks ago after them being on for 1.5 years. You could see where the valve stems where worn. It was all on one side of the stem, when it should be all over the top.
Also shows the valves were not rotating like they should IMO.
Old Dec 4, 2005 | 12:25 PM
Car: 91 Camaro
I've been running my 1.6s for atleast 2 years and haven't had any problems. I'm surprised you were able to see any wear with the roller tip, regardless of the angle. do the rollers still turn?
Old Dec 4, 2005 | 04:06 PM
TVRPAUL's Avatar
Hi again
Just what would going to the 1.6 RR do? would it reduce torque & extend the top end + it puts more load on the cam?
Paul
Old Dec 4, 2005 | 09:40 PM
Car: 91 Camaro
they will give you more valve lift which should help topend power. i wouldn't think they'd hurt your torque any, though. they won't put that much more load on the cam.
Old Dec 5, 2005 | 05:44 AM
Dale's Avatar
Engine: 350 S-TPI
I tested a few, and the tips still did roll.
Center of roller was right at the edge of the valve stem.
Fully open, center was about center on the valve stem.
Old Dec 5, 2005 | 03:34 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
for the $$$$$ of full rollers, you can get a cam that will do more w/the rockers and still have some scratch left
Old Dec 9, 2005 | 05:02 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
do you know what pushrods you need when installing these rockers then?
Old Dec 9, 2005 | 08:33 PM
Dale's Avatar
Engine: 350 S-TPI
This was over a year ago, so dont cuss me if this is wrong.
I belive it needed to be 6.28" long. I found some OTC mufstang pushrods at 6.25 which is longer then ours, and IMO close enough. I never did buy them though.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
