True Ram Air Intake
Old Feb 22, 2006 | 02:44 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
True Ram Air Intake
What do you think of this design? It seems like a good idea but will the radiator receive a lack of air??
Old Feb 22, 2006 | 02:53 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
that has been done before.
Old Feb 22, 2006 | 05:57 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
It just makes the Camaro front end more like a Firebird, as far as radiator airflow. Just make sure you have an air dam.
http://www.hawksthirdgenparts.com/inc/sdetail/779
Old Feb 22, 2006 | 07:43 PM
iroc-z's's Avatar
Car: 88 camaro rs
Transmission: auto
i was thinking of that design myself didnt know that hawks sold something like this
Old Feb 22, 2006 | 10:17 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
the dual snorkel setup flows enough for a v8 already, its probably not gonna help a whole lot on our engines. i noticed a bit more gain at the upper rpm's when i gutted the air boxes, try that. and for $100 youd be insane to buy it. you can make that exact same setup for probably $15 by going to home depot and buying the stuff for yourself.
Old Feb 22, 2006 | 10:48 PM
daves12secV6's Avatar
if u run hot with the air ducts run down, u can take one of the ducts off.Then on the side u took the dust off replace the air filter on that side with a blockoff plate.this way when the air is going in the one side it dosent just blow out the other side . used to run my iroc like that, one side flows more then enough for a v8,
Old Feb 22, 2006 | 11:13 PM
TpiTony's Avatar
Car: 1991 Camaro Z28
Engine: 305 Tpi (and not the average)
Transmission: 5 spd warner
I need the factory parts!
I like the idea and I have made on out of a mold I created a year ago. Mine was fiberglass. watch your temp man, I had a 305 and it got hot because I dident have the lower schroud.
But newho I am looking for a website that sells the OEM style parts that are designated in green on your diagram. From the throttlebody to the cover that hold the air filters.
Please If anyone know please let me know,
Thanks,
Tony
Old Feb 22, 2006 | 11:19 PM
i took my lower air dam off long time ago,was always bottoming out on stuff with it and i cracked it.havent had a problem with the car running hot though,even with the ram air setup
Old Feb 23, 2006 | 12:22 AM
TpiTony's Avatar
Hmmm???
On what size motor, a 305 needs a whole lot more air to keep cool than a 3.1
Old Feb 23, 2006 | 12:26 AM
i have done that ram air thing on my iroc with 350 and my rs with the 2.8 niether run hot,thats why i said just do one side and make a block off plater for one side.still lets air get to the radiator
Old Feb 23, 2006 | 12:33 AM
TpiTony's Avatar
Cool Thanks!
neways do you know where I can find the ramair stuff, which is designated in the green above?
Old Feb 23, 2006 | 12:42 AM
well i mad emine out of sheet metal at work .080 aluminum that i cut and shaped then welded, but u can get stuff from home depot, that u can use,flexible ducting etc
the green is the factory duel snorkle air box
Old Feb 23, 2006 | 08:32 AM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Re: Cool Thanks!
I am looking for some too. I think ebay or your local junk yard is your only choice.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
