2.8 runs rough! why? replaced HG
Old Mar 4, 2006 | 02:49 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I bought this 88 camaro 2.8 MPFI from ebay. I was told it had a blown head gasket so I replaced the gasket. I've got it together and started the car. It runs bad. It shakes and putters. What could cause this? Sensor, vac line, valve lash etc. ?
Here is a pic of how my dist. looks installed. The dark spot on #1 is what I chose for the #1 spot on the cap. Is this correct? To make it idle I have to turn the cap as far as it can go and that doesn't seem right. If I could turn it more I would but it won't move anymore.
Why are there 3 marks on the balancer? I chose the larger of the three and set it to 0 on the timing tab. I made sure I was on the compression stroke and that the piston was at TDC.
File Type: bmp
Old Mar 4, 2006 | 02:51 PM
micali's Avatar
Engine: 2.8
If the file doesn't work please tell me how to do it. Thanks.
Old Mar 4, 2006 | 02:57 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
from what i see.. u have #1 in the right place..
Old Mar 4, 2006 | 11:08 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
#1 is the front cylinder on the passanger side... are you sure you got that right?
Old Mar 4, 2006 | 11:46 PM
micali's Avatar
Engine: 2.8
yes. 1 3 5 is on the ps side and 2 4 6 is on the dr side.
I know you have to have #2 cyl. up at TDC before you can stab the dist.
Old Mar 5, 2006 | 07:58 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
timing should be at 10 while running and est disconnected.
What town you in?
Old Mar 5, 2006 | 08:42 AM
micali's Avatar
Engine: 2.8
what is est? and I am in rogers, ar
Old Mar 5, 2006 | 10:28 AM
Dale's Avatar
Engine: 350 S-TPI
Rogers, ok I belive thats up by fayette right? 3 hours from me.
EST is electronic spark timing, its a wire you have to disconnect thats over by the right strut mount, and your heat/air shizzel. Its brown wire.
Then start the car up and adjust timing to 10deg.
Tighten dizzy back down
reconnect wire.
How did you adjust the rockers?
Do you have one of the haynes/chiltons manual? If not, its 20 bux wisely spent.
Old Mar 5, 2006 | 07:13 PM
micali's Avatar
Engine: 2.8
my buddy did most of the work while I wasn't there. After the heads were installed he counted a certian amount of turns, once it was loose enough he put in the pushrod and then tightened them down the same amount of turns it took to loosen the rocker up. I know if they are to tight the car might run like crap.
No I haven't picked one up yet. I can go to autozone.com and find out most anything I need. I didn't find this until we were almost done. I'd hate to pull the valve covers off. Man that sucks.
Yeah, it's about 25 min or less from fayetteville. Were U?
Old Mar 5, 2006 | 09:11 PM
Dale's Avatar
Engine: 350 S-TPI
Counting the turns on how much it loosed is not a an accurate way at all. After the pushrod has some drag on it, you turn it 1.25-1.5 turns more.
That is, when thats the compression cylinder as well.
How your dizzy picture is, is not how mine is. My plugs are facing the rear more on mine.
Also re-check your timing with the est disconnected.
Im in LR, NLR, Sherwood, Jacksonville area. Basically, central arky.
Old Mar 5, 2006 | 10:32 PM
micali's Avatar
Engine: 2.8
all 6's should have the same firing order and placement. How are yours done?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
