Trying to pull engine codes
Old Mar 23, 2006 | 05:55 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I tried to pull the engine codes from my ecu and when I jumper it the check engine light only flashes one time. What's up? You jumper the two end spots, all the way to the right top and bottom, correct? If so I did it right and couldn't get any flashes.
Old Mar 23, 2006 | 06:20 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
Sounds like ur just not making a good connection.. Are U just using a piece of wire.. or a paperclip.. best is a code reader.. and not use the SES light at all..
Old Mar 23, 2006 | 06:33 PM
micali's Avatar
Engine: 2.8
yeah just a paperclip, don't have a code reader. It's always worked before, with my other cars.
Old Mar 23, 2006 | 06:44 PM
madathlon's Avatar
Well there a chance you push one of the terminal out the back of the OBD block..
Old Mar 23, 2006 | 06:48 PM
micali's Avatar
Engine: 2.8
well, I can still see the terminals. I didn't push that hard. I'll go to Autozone and pick up one of those metal code keys and see what happens.
Old Mar 23, 2006 | 06:56 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
No. Not top and bottom. You got an '88, some of the earlier cars it was top and bottom.
you need to use the last 2 end spots on the top. (The one on the right end and the one to the left of it both on the top row ) the radiator fan should run continuously while the key is on and the pins are jumped if you have it right.
Old Mar 23, 2006 | 06:57 PM
micali's Avatar
Engine: 2.8
that might explain things
Old Mar 24, 2006 | 02:07 PM
micali's Avatar
Engine: 2.8
did it, pulled the 12 code and nothing after that. I had it running last night and the ses light was on. I am trying to restab the dizzy, not sure If I am doing it right.
Old Mar 24, 2006 | 04:34 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Nevermind, all ready posted
Old Mar 24, 2006 | 05:28 PM
91 v6's Avatar
Car: 2002 ranger(showtruck) 90 firebird
Engine: 3.1l
code 12 is just no disributor pulse you will always get that when the engine is off
Old Mar 24, 2006 | 05:31 PM
micali's Avatar
Engine: 2.8
I know, but what's wierd is that it didn't flash anymore codes.
Old Mar 24, 2006 | 08:54 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Did you disconnect the battery at any point recently? If so, you cleared the codes and will have to drive the car until the light comes back on, then pull the code.
Old Mar 25, 2006 | 12:15 AM
91 v6's Avatar
Engine: 3.1l
how many cycles did you watch. it will flash 12 12 12 then the next code and so on until it comes back to the first. just went through my car recently and mine read 12 12 12 23 23 23 42 42 42 then back through again
Old Mar 25, 2006 | 09:54 AM
micali's Avatar
Engine: 2.8
Well, I watched the cycle and no other codes were shown. I think I need to let it run a little longer and see what happens. If I can get it running agian
Old Mar 25, 2006 | 10:06 AM
madathlon's Avatar
U know.. I had a similer problem at 1st.. I couldnt get codes by the SES light.. But I went out and bought a Xray 6000 Code reader/programmer and it was abe to read all the codes on the ECM.. I think if there to many codes the ECM just cant handle them and locks up.. I ended up needing just about all my sensor replace.. Temp, MAF, O2, Trigger, so on so forth..
Old Mar 25, 2006 | 02:02 PM
91 v6's Avatar
Engine: 3.1l
i just went through something like that except after 4oo bucks i found out to have a bad ecu i changed a lot of junk and was fed up and for ha ha changed the ecu and it ran
Old Mar 25, 2006 | 02:58 PM
madathlon's Avatar
I didnt need a ECM.. It was just to full of codes.. But once I got all the code and replace it all.. The car did pass Ca Smog.. so I was much relieved on that part..
Old Mar 25, 2006 | 06:28 PM
micali's Avatar
Engine: 2.8
I wonder if I hurt the ECU when I jumped it wrong? Now all I get is backfire when I try to start it.
Old Mar 25, 2006 | 06:31 PM
madathlon's Avatar
Thats a good way to fry it...
Old Mar 25, 2006 | 07:01 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
I don't believe there is any voltage on the bottom right connector. Let me find my pinout.
http://www.troublecodes.net/GM/ Says that the bottom right connector is serial data. All you would have done by connecting the rightmost top and bottom pins is to connect the serial data line to ground.
If GM engineered the ECU correctly then its optically isolated, and no harm done. If not than at worst you destroyed the serial controller. The whole computer is not broken. Rest assured.
Sort of like if you took your printer cable apart and shorted everything together. You might get a tiny spark, and maybe that port won't work anymore, whole computer shouldn't be affected.
Last edited by bobdole369; Mar 25, 2006 at 07:05 PM. Reason: Automerged Doublepost
Old Mar 26, 2006 | 06:57 AM
91 v6's Avatar
Engine: 3.1l
when my ecu went bad the car would start and stall right away, or start and run smooth till you touched the throttle or start idle and run smooth for a min and then idle reallt rough
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
