pics of o2 wire?
Old Apr 2, 2006 | 09:21 PM
drgn's Avatar
Car: 92 camaro
Engine: 3.1
Transmission: 5spd
pics of o2 wire?
Hey guys, I have a 91 v6 and the wire for the o2 is missing. it has been cut or pulled out of the o2. I have another sensor, but I cannot find the wire to plug it into. can you help?
Old Apr 2, 2006 | 09:49 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
[IMG][/IMG]well, i can try...but i have a 305...but here is where it is on mine
Old Apr 3, 2006 | 07:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The O2 wire comes out of the harness under the hood on the passenger side (US pass side). At the rear of the engine compartment. IIRC it is a dark color, black with a red stripe? The sensor mounts in the Y-pipe under the vehicle.
Note that some export models are for leaded fuel. In these vehicles GM cut the O2 sensor wire to prevent closed loop operation.
RBob.
Old Apr 3, 2006 | 08:57 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
shouldn't those cars running on leaded fuel be (relatively) easy to spot due to the absence of the cat convertor?
Old Apr 3, 2006 | 10:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually I'm pretty sure it's a purple wire; should be hanging around by the back passenger side of the motor.
Old Apr 3, 2006 | 11:48 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
x2, with a white stripe. It comes out of the harness that runs down the back right side of the motor and goes to the starter. But they pull it out about halfway up.
Old Apr 3, 2006 | 06:24 PM
drgn's Avatar
Car: 92 camaro
Engine: 3.1
Transmission: 5spd
y-pipe huh? thats really strange. thats where I thought it would be, but what, then, is in the passenger side manifold of my car. it looks just like an o2 with no lead coming out. what is this then?
Old Apr 3, 2006 | 07:38 PM
Dale's Avatar
Engine: 350 S-TPI
someone may have put a 3.4 in, with 3.4 manifolds.
Any way you can take pics of it?
Old Apr 4, 2006 | 01:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So 3.4's have the oxy sensor in one manifold?
Another possibility is that someone put a 3.4 manifold on his 3.1?
Old Apr 4, 2006 | 02:09 PM
Dale's Avatar
Engine: 350 S-TPI
Both, 3.4 is a dual(left/right) setup.
stalkier
Dec 6, 2015 11:25 PM
blackandblue02
Sep 10, 2015 08:19 PM
Fox118
Sep 1, 2015 04:07 PM
Bimma86
Nov 22, 2001 09:32 PM
87_Camaro
Oct 16, 2001 09:05 AM
