Will headers make a difference?
Old Apr 30, 2006 | 08:41 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
I have an opportunity to get a set of pacesetter headers, but are they worth it? Will they make a difference on a 2.8? Anyone ever install them on their 2.8? Will it be a tough install? They don't have the ceramic coating, is there something I can do for heat protection or will they be ok as is?
Old Apr 30, 2006 | 08:47 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
what do you have done to your exhaust so far? catback? highflow cat? if theres nothing done, get the headers and a dynomax catback exhaust, youll love the sound and performance gains. it takes about 2-4 hours depending on your mechanical skills. and i cleaned the factory paint off mine and got high temp paint on mine and its lasted close to 8k miles.
Old Apr 30, 2006 | 08:51 PM
Car: '88 Camaro
Engine: v6-173-2.8L
have a regular cat with a flowmaster catback system.
Old Apr 30, 2006 | 09:13 PM
drdave88's Avatar
Engine: 6.0L
headers will make a lil bit of difference but its still a big gain over stock manifolds. and get felpro header gaskets, the pacesetter ones blow out too quickly. oh and get some locking header bolts, youll be glad later on.
i just noticed you have a camaro. gut your air boxes if you havent done so already. youll notice a gain in the upper RPMs.
Old Apr 30, 2006 | 09:25 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
header bolts
do have a link for the locking header bolts?
Old May 1, 2006 | 10:06 AM
Car: '88 Camaro
Engine: v6-173-2.8L
do you have a link for the gasket and the locking header bolts? Having trouble finding them.
Old May 1, 2006 | 09:21 PM
Car: '88 Camaro
Engine: v6-173-2.8L
So, is this a tough install. I heard that you have to remove the alternator and the A/C compressor. My mechanic told me to not bother with locking bolts and just use heavy duty loctite. Does the pacesetter header kit come with torque specs and tightening pattern.
Old May 2, 2006 | 09:24 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Originally Posted by Six_Shooter
Nice to see I can't put my opinion into a thread, without it being ****-ized.
I kinda semi-agree. I think it would give the same effect as removing the cat. Loose low end, gain top end.
However, like any other mod. On a stock engine its not crap, but once you start doing other things, its better.
Old May 2, 2006 | 01:11 PM
Drew's Avatar
Seriously, why would you bother?
Headers are never a drop in swap. There will be things that have to be removed, brackets that won't line up right, parts that have to be fabricated, gaskets that blow out periodically, bolts that will break off in the heads...
All that for a louder exhaust and maybe a bit more power?
Old May 2, 2006 | 02:17 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
DO NOT USE LOCTITE IN YOUR BLOCK just get allan headed bolts so you can actualy get a bit on them and chack them every 3K. or do the locking bolts (search summit). but DO NOT USE LOCKTITE in your block. and fire that mechanic
Out-Cast
Mar 22, 2019 09:39 PM
onefreakz
May 14, 2018 12:15 PM
sreZ28
Aug 14, 2015 07:48 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
