My camaro died :(
Old May 23, 2006 | 12:53 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My camaro died :(
My camaro will not start up at all it is getting fuel but just keeps cranking and cranking all the wires and parts seem ok. Any ideas it ran fine lastnight and this morning i drove about 1/4 of a mile and it turned off and never turned back on again.
Old May 23, 2006 | 09:51 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Do you have spark? Verify that, first...
Old May 23, 2006 | 11:10 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Originally Posted by FAST RS
it is getting fuel
Silly question, but you verified this with a Pressure guage, right?
Like Doward said, verify spark and go from there.
Old May 24, 2006 | 02:55 PM
Steve's Avatar
Car: 91 Z28
I feel for you FAST RS. My car did the exact same thing yesterday. I was driving it and it just died. I still have fuel, but no spark anymore. I will have to take a long look what failed there. Any suggestion would be helpful.
Old May 24, 2006 | 03:07 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ignition coil or pickup coil?
take out a spark plug and crank it over to verify a nice bright spark.
Old May 24, 2006 | 11:23 PM
FAST RS's Avatar
I am going to take it to the shop I tried to do what i could tongiht but I had no one to crank the car no tools and it is infront of the management office. It was running perfect all weekend and then it just turned off. Last night when I tryed to start it it sounded like it wanted to turn over but didnt. It did this a few months ago and no one could find the problem.
I did end up buying another car as a daily driver got a 03 Lancer rice yes but needed a cheap car on gas.
Old May 25, 2006 | 08:19 PM
FAST RS's Avatar
I had my car towed to the shop today helped them work on it and we came to the conclusion it is the ICM The coil has spark but the wires dont.
Old May 28, 2006 | 06:47 PM
FAST RS's Avatar
This is all I have to say about my ICM.
"Built to last DURA CRAP"
Old May 29, 2006 | 06:02 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
How do you have a coil that's putting out but not getting anything out of the wires and determine that the ICM is bad? If you are getting the coil to fire, the ICM is fine, it's something in the secondary that's toast, unless you are bench testing the coil. Did you see how they did it?
Old May 29, 2006 | 06:05 PM
FAST RS's Avatar
Let me rephrase that I was half asleep when I posted it. Power is going to the coil but when the ICM was tested it was bad.
Old May 29, 2006 | 11:55 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
OK, that makes more sense, I'm not nearly as lost now...lol
Old Jun 6, 2006 | 03:28 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
? ok ima lil lost ,.,.if there is spark but not in wires would the secondary area be the rotor? please understand im not sure what the icm is.,., ive alyea been hands on with my car when i trace back probs and bench tast i take parts to shop and say gimmie one of those right there,.lol,.
Old Jun 6, 2006 | 07:09 AM
Car: IROC Z
Engine: 5.7
not to be a *****, but i dont know what your saying when you spell words wrong. and how i test for spark is (if im by myself) i roll down the driver side window and pop the hood, take out one of the spark plugs off the driver side, attach it to the plug wire and while leaning over the windshield with one hand on the spark plug, and one hand on the ignition key i turn it over for a sec. if i feel a shock then its got spark.
you can also put this spark plug directly onto the coil to test for spark there. if you have spark at the coil, but none when it goes through the dis, then it may be a problem with the cap and rotor. maybe even the pickup coil? (im not sure about that but when my car died, it was the prob)
Old Jun 6, 2006 | 07:48 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
lol, there are easier ways then electrocuting yourself.
jklein337
Sep 19, 2018 06:23 PM
pimp2303
Jul 27, 2017 02:03 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
legendaryhero7
Aug 12, 2015 06:19 PM
