Turbo oil lines and engine update...
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Well my engine turned out to only have blown a head gasket.. It looked like somebody took some metal sheers to it but the new ones are on and my engine is gonna start coming back together soon. My turbo is gonna be mounted on the passenger bank of the engine with both banks feeding it. For the return line Im just gonna plug it into the front of the pan. The feed line is posing more of a complication.. I have to T-off the pressure sending unit and run a line but its on the other side of the engine. Should I run the line over the top of the engine or underneath and secure it to the sub-frame/crossmember?? Either way will work but I was thinking maybe the line could get damaged under the car.. A friend is helping me edit a slideshow/video when everything is done from before the turbo all the way to when its running. Im gonna keep the MAF setup as well due to lack of funding lol..
<< Soon hopefully...
<< Soon hopefully... i ran 4-an feed line off a tee at the sending unit along the frame rail down to the crossmember to the pssenger side for mine. what size lines are u using?and what kind of line rubber/steel/braided hose etc?
Transmission: 5-speed/T-5
I ran mine in front the engine over the T-stat housing, and past the head, just to sort of give you an idea on layout.
Would I be able to run the return line where the drain plug is??? Itd be easier than drilling/tapping another hole... And when doing an oil change you could still just unscrew the line..
Damn! Alright well I guess I have to weld a bung and punch a hole in the pan.. Could I just get a big nut and weld it on?? Are rubber lines ok to use.. I dont have much money left to spend otherwise Id go braided..
Yeaa I was wondering about that as well.. Is anybody with a turbo'd 660 using an oil cooler???
Well with the exhaust manifolds switched the one I had planned to mount the turbo ontop of points downwards.. Im gonna see if the 3100 manifolds will help any.. Im gonna start cleaning up my heads tomorrow morning, rig up my A/F guage and prolly get the exhaust mocked up.. Things are goin pretty smooth now..
Well 3100 ex. manifolds didnt help any, guessing Im gonna have to go custom now.. It pisses me off cause I was hoping to have this done by the weekend
.. But now I have to make a header wich is gonna take most of my time.. Its not gonna be anything fancey.. Just something to get the job done..
.. But now I have to make a header wich is gonna take most of my time.. Its not gonna be anything fancey.. Just something to get the job done.. do ur self a favor,so u dont run into the problem i just had,when u hook up that a/f guage, install asecond 1 wire o2 for it to run off of dont tap inot the one hooked to the ecm,autozone seels the 1 wire o2 for our cars for 19.99,and summit has 02 bungs for a few bucks
Haha!! I must be in luck seeing as I have a spare un-used 1-wire O2.. How can I tell where the oil level is so that I dont f'up and have a hole in my pan for no reason? I cleaned up my heads earlier today.. I must say they look alot better.. Not much of a port job cause I dont have a flowbench but I did take off a good amount to gasket match them.. Should I be worried about anything?? Does anyone have a link to the instructions on making a MBC?? Im only wanna run 5psi until I get the bigger injectors and make sure the engine is running good..
Well after using a whole can of PB blaster, the exhaust manifold bolts still snapped.. Only about 5 of them actually came out.. 7 of them werent there or snapped.. I quite aggrivated but hey.. I got spare heads lol.. Where can I buy new bolts, Im gonna check Advanced a lil later on in the day but I was wondering if there was a ARP set or something?? Thanks
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Where exactly is the oil sending unit? And would it be possible to have the oil return into the valve cover like on the STS turbo kits?
Originally Posted by daves12secV6
the oil return must be below the turbo,turbos use gravity drianing
What about the oil sending unit, where is it located?
Originally Posted by RSFreak
Yeah, I guess the STS kit uses an electric pump to return the oil.
Navy8125
Aug 21, 2015 09:32 AM
