Starter Shims question
Old Jun 21, 2006 | 11:02 PM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
I have a 2.8L MPFI V6, the starter needed replacing, I replaced it and put the shim in that came with the new starter,but WOW what a noise when I turned the key. The engine still turned over, but what a noise!!!.
So, I removed the shim and the noise was a little less, but still loud.
Anybody have suggestions?
Old Jun 22, 2006 | 10:34 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
How many shims did the old starter have under it? I've always been told that you use the same number of shims that was on there. You might want to take your starter down and check for damage on both the starter and Flywheel. Its very possible that you wore some teeth down or broke them off....and the noise is the lack of engagement of the teeth.
Old Jun 22, 2006 | 01:04 PM
87pontiac's Avatar
Car: 87 Firebird
When the old starter came off there were no shims.
Old Jun 22, 2006 | 03:28 PM
Did you look at the teeth on the starter and flywheel?
My guess is that by using the shim, you increased the clearance between the gear teeth, and as a result, you damaged the teeth on one or both. Now that you have worn down the teeth, you still don't have correct engagement. While you can get your flywheel to spin fast enough (takes longer now right?) the teeth are sliding off of each other earlier than normal causing the next tooth to crash into its counterpart on the flywheel.
Old Jun 22, 2006 | 09:36 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i had a similar problem like this once, try putting it in with no shims, sometimes the aftermarket starters especially the duralast ones don't require them, worked for me in both my 6 and my 8
Old Jun 22, 2006 | 09:51 PM
87pontiac's Avatar
Car: 87 Firebird
I will be taking a closer look at both the flywheel and the starter this weekend when I get the car up in the air. I just found it funny that when I put the shim that came with the starter in, it made it worse, and removing the shim, improved it somewhat).
I'll let you know when I find out how the teeth look.Also, on the V6 engine, shouldn't there be a bracket attached to the rear of the starter that attaches to the engine, I don't have one, could the starter flex under load to misalign itself just enough to be off sync with the flywheel?
Thanks Alot!!!
Old Jun 22, 2006 | 10:05 PM
While I've seen other cars with the same starter and a "rear" bracket, I've never seen a Camaro or Firebird with one, though if there is an available bolt hole, it couldn't hurt.
Maybe on the 2.8 the bolt hole wasn't cast into the block for some reason?
Old Jun 28, 2006 | 05:43 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It doesn't matter how many shims you have in there as long as you have a 1/8" gap between the center shaft of the starter and the flywheel. If the gap is currently too large with no shims in, you might need a different starter with a different drive end housing. If you still have your old starter, I suggest swapping over the drive housings to see if that helps (an old trick used by techs when replacing starters so we don't have to go through the measure and check BS). If the gap is too small, then you obviously need to add shims until it's right. I currently have 1/4" (that's right... you read it correctly if you read 1/4" ) of shims in between my engine block and the starter housing, and she's nice and quiet...
Also, the 2.8/3.1 engines do NOT have a rear starter bracket.
Old Jun 28, 2006 | 06:05 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
srry to jump subject, but how hard was it to replace
the starter?
i got a 91 RS and my starter's showing some age,
so I want to replace mine.
i got a 3.1L MPFI I believe same structure as ur car
and its an automatic, thanks!
Old Jun 28, 2006 | 06:19 PM
Engine: 2.7L V6
Axle/Gears: 4.41
the starter?
Disconnect batt negative cable.
Disconnect positive cable at starter with purple solenoid wire and fusible links.
Remove starter bolts while holding starter so the 20 pound starter does NOT hit you in the head.
Pull starter out of the dust cover towards the front of the car. Drop the tail end down and out it comes.
Old Jun 29, 2006 | 12:02 AM
sogabe's Avatar
Engine: 3.1L
cool, sounds simple.
but should i take cautious not to hurt the flywheel or something?
i never really observed that area.. but i think nextweekend or so im gonna
tackle that, thanks!!
Old Jul 3, 2006 | 03:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
It's going to take a lot to hurt the teeth on the driveplate. Just don't use a hammer on the teeth and you'll be fine. Keep in mind that you need that 1/8" of clearance between the teeth and the starter shaft otherwise you'll do some damage when you reinstall the starter (or install a new one).
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
