a good v6 to start with
Old Jul 4, 2006 | 02:02 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
ok heres the idea, i want to put a chevy rwd v6 (or even a ford v6, i know what your thinking because i dont like the idea eather) into a 2ed gen mazda rx7. why a v6 you might be thinking, well its because of 2 reasions
1: to keep it light
2: so i can run in the "import class" at the local track
i would like the motor to be fuel injected because i know more about that then carb, when im dont im looking to run it in the 1/8 miles and it will be eather twin turbo or one big turbo, so the CR will have to be low to mid 9's any ideas???? i was thinking about eather a 2.8 or a 4.3 v6 (i like the 2.8 better because its not tbi)
any other motors you can think of? I dont really know anything about chevy v6s so please be kind in my school'in
Old Jul 4, 2006 | 04:40 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
there is a user on here that has a 2.8 motor in an rx-7. His usere name is Leo Padkin or something like that. Look him up.
Old Jul 4, 2006 | 04:57 PM
daves12secV6's Avatar
2.8 or 3.1 with a single turbo,will be more then enough.atm i have a single to4e stage 3 on my motor running 11 psi.though the boost level will be geeting kicked up quite a bit from there pretty soon
Old Jul 4, 2006 | 05:47 PM
high c's Avatar
Car: 86 iroc
thanks for the re guys
and it looks bad ***, befor i asked the Q i did some looking and i found your page....so how fast is she?
Old Jul 4, 2006 | 06:59 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I'd suggest a 3.1 from the later thirdgen years, or the 3.4 from the early fourth gen years. I'd pick the 3.4 for more displacement.
Old Jul 4, 2006 | 07:43 PM
should be pulling a high 12 sec pass tommorow,but my engine is away of from stock
Old Jul 4, 2006 | 07:49 PM
high c's Avatar
Car: 86 iroc
you wouldent happen to know what the CR are on the motors would you??
Old Jul 4, 2006 | 08:00 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
whats up guys
Old Jul 4, 2006 | 08:52 PM
high c's Avatar
Car: 86 iroc
Originally Posted by Leo_padakin
whats up guys
i have so many Q i would like to ask you,
what did you use for a motor cradle?
was the swap hard to do (wireing and all that stuff??)
it go good??
Old Jul 4, 2006 | 08:55 PM
2.8 is 8.9-1 and i belive the 3.1 is 9.0-1
Old Jul 4, 2006 | 09:32 PM
it go good??
motor mounts from the wankel were cut out, and motor mounts where made out of 3.5 in steel sqare rail, and some .5 inch sheet metal, mocked up welded in...same for tranny, had to cut hole in floor of tranny tunnel. the hole that was there needed to be moved 5 inches forward. most of the wiring was pretty strainght forward. certain parts of each others harness needed to be spliced togetherto get a/c radio, ect. to work...you need to get a oil pressure sending unit, and run that wire.. and i cant remember the company name right now... but... you need to buy a conveter for your speedometer to work, camaro speedo is cable driven... but the rx7's isnt or somehting like that.and the exhaust has to be changed brfor the y pipe from the manifold.. and electric fans.... even though mine never work
Old Jul 5, 2006 | 04:04 PM
high c's Avatar
Car: 86 iroc
sounds pritty stright forward, im not worryed about the speedo because im not planing to run one, just a tach and a oil psi, boost and water temp , do you take the 7 to the track at all or is it just a drive around town car? what kind of mpg do you get?
Old Jul 6, 2006 | 01:31 AM
nope never went to the track, just a daily driver... with 4.10 gears,and no weight....a really fun daily driver.i guess that good about the speedo, because you have to take apart the gauge bezel, solder in a resistor, and connect it to a car battery charger to get it to read right. my only problem is wen it rains first gear is useless, second barley let me go with out smoking tire. but go to grannysspeedshop.com they sell all sorts of kits for different engines into the rx7...from chevy to ford..hell even one to put in a 300zx engine in it. have fun
Old Jul 6, 2006 | 10:33 AM
Toehead's Avatar
Once he has the engine swapped in he can always build an aldl cable and read the speed on his laptop, if he wants to drive it on the street.
Old Jul 6, 2006 | 12:37 PM
well i mean its wasnt hard... only took about an hour.... just some people hate soldering.. i really kind of enjoy it(at times )
Old Jul 6, 2006 | 12:59 PM
Toehead's Avatar
Ya... What do you mean "connect to a car battery charger"?
Old Jul 6, 2006 | 05:56 PM
go to www.grannysspeedshop.com , scroll down near the bottom... look for v6/v8 tach recal
Old Jul 7, 2006 | 12:42 AM
Toehead's Avatar
That is darn slick.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Lmancha96
Sep 25, 2015 08:11 PM
